PIC16F886 not running.
Results 1 to 20 of 20
    Jan 2015
    Default PIC16F886 not running.
    Hello everybody.
    I need help. I just cant get a simple blink-program to work with picbasic pro. I have tried the same (almost) program in GCB, and the chip works.
    No problem when I compile.
    Is there any kind soul out there who can help me getting started with PBP3, so I can blink the d***m LED??
    Default Re: PIC16F886 not running.
    Let us see what you have got, and we will help YOU make it work.
    read data sheet re:ANSEL ANSELH ADCON0 ADCON1
    PICs typically default to analog ports and YOU MUST tell them to do digital.
    Jan 2015
    Im not very good at pics yet, but im learning
    This is what I have. I just want the PIC to light up. I have the LED connected to PORTB.0
    I have tried a lot of different examples, but none works.
    __________________________________________________ _
    TRISB = %11111111
    TRISC = %00000000
    ANSEL = %00000000 ' Make AN0-AN7 digital
    ANSELH= %00000000 ' Make AN8-AN13 digital
    PORTB = 1
    portb=1
    __________________________________________________ ___
    This works in GCB, but I think that compiler does a lot in the background for me.
    Jan 2015
    Updated code
    TRISB = %00000000
    ADCON0 = %00000000
    PORTB = 1
    portb=1
    To make it blink you have to turn it off too
    PortB.0 = 0
    Do you have a config statement.
    Don't forget to tell PBP whay Oscillator speed.
    I have not studied this chip but it has OSCON registers and OSCTUNE registers.
    Try OSCCON = %01100000 sets oscon to 4mhz (default)
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Um........That wouldn't blink the led (which is on PB0?) it would just turn it on permanently.
    Your main should be something like...
    portb.0 = 1
    portb.0 = 0
    Could also be
    portb = 0
    portb = 1
    Hope this helps.
    About time I offered some help, instead of just asking for help, for a change.
    Peter Moritz.
    New South Wales,
    Australia.
    Hi, Peter
    Have a Happy new Year !
    we also could write it :
    PORTB = 0
    TRISB = %00000000
    ADCON0 = %00000000
    WHILE 1
    TOGGLE PortB.0
    pause 300 ' just to see something ...
    WEND
    Note PBP+ chip defaults are not shown here ... but [no]don't[/no] NEVER forget they exist !!!
    Jan 2015
    Hi everybody and thanks for all the input.
    Youre right, it wont blink. I just want to get the LED light up so I see that something is happening. For now, nothing works and no LED lights up. I have connected LEDs to all PORTB, so I can see if anything is going on on the chip.
    I have tried all of your suggestions here but still dont work.
    I thougt that the CONFIG was in the INC-file in PBP? Do I have to write something in code to make it start?
    a little scheme ( the real one ... ) would be useful now ... especially for the RESET pin ...
    Jan 2015
    I did a schematic in PCB express and this is exactly how its connected. I just want some LED to light up.
    This one works perfect then I use GCB and PICPgm to program the chip. I use PICPgm to program it now too.Name:  scheme.jpg
    Updated the code to use some LEDS on PORTC too, but no luck...
    OSCCON = %01100000
    PORTB = 0
    PORTC = 1
    TRISB = %00000000
    TRISC = %00000000
    ADCON0 = %00000000
    WHILE 1
    TOGGLE PortB.0
    toggle portc.0
    toggle portc.1
    WEND
    Dec 2014
    Osccon = %01100001
    default pbp3 fuse config
    __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    yet you have no pull up resistor on mclre_pin (1)
    no vss on pin 8
    no current limiting resistors for leds ( will cause rmw issues)
    what is that unspecified thing between portb7 and mclre ?
    LilleJung,
    PLEASE ....
    open your Datasheet and begin by the supply circuit, then the Reset (MCLR) wiring ... one more trail from those, and your '886 is fried ...
    PS:@ Skimask: ... the well known guy ???
    May 2007
    Quote Originally Posted by Acetronics2 View Post
    http://www.picbasic.co.uk/forum/show...436#post130436
    Jan 2015
    YEAH!!!, almost.....
    The config statement helped a bit, now the LEDs on PORTC blinks. But nothing on PORTB.
    I set MCLRE_OFF instead of MCLRE_ON and now I even can have the programmer connected and the chip works.
    I have a pull-up resistor on MCLR also, but it works without it too. And current limiting resistors on the LEDs.
    Now all I want is to get PORB to blink, then im up and running. I really want to migrate to PBP. GCB was great, but a little too many bugs for me.
    PORTB.6 and PROB.7 is always connected to the programmer circuit (a homemade AN589 programmer).
    The thing is that when I used the original circuit and wrote the code in GCB, everything worked...
    New code...
    #config
    #endconfig
    OSCCON = %01100001
    PORTB = 0
    PORTC = 1
    TRISB = %00000000
    TRISC = %00000000
    ADCON0 = %00000000
    WHILE 1
    TOGGLE PortB.0
    toggle portc.0
    toggle portc.1
    WEND
    Jun 2005
    Your schematic also is not showing a connection between the programmer and negative power (Vss)
    I imagine that should be the spare terminal on the program connector?
    Which programmer are you using?
    Peter Moritz.
    New South Wales,
    Australia.
    Dec 2014
    Quit using TOGGLE. It's a R/M/W instruction. Set it high, pause, set it low, pause, loop.
    Suggest reading the first few chapters of PBP manual.
    Jan 2015
    The circuit works. If i do the same thing in GCB, I have no problem. Its just to get PBP to do the same thing. But the config solved most of it. just a few things left, like make the analog to digitla outputs. But I hope to solve that tonight.
    Im using a AN589 programmer, and its works great with code from GCB.
    I did read the first chapters, but I just couldnt get the PIC started.
    Somehow the portb is solved too. I changed PortB to portb, programmed it, and now, for some undefined reason. it works....
    After that, I can use PortB (with caps) again and it works!!!
    Dont know why, dont care for the moment, im up and running...
    Thank you all for all the help.
    Ill be back if something else wont work for me.. :-)
    Search the forum for ALLDIGITAL. It will help you determine what you need to make all pins digital.
  1. Replies: 8
    Last Post: - 28th January 2014, 15:21
  2. Config problem PIC16F886
    By Bosse in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2014, 07:24
  3. pic16f886
    By NURULHAIZA in forum General
    Last Post: - 21st May 2010, 09:09
  4. PIC16F886 Register Settings
    By aherrera in forum mel PIC BASIC Pro
    Last Post: - 29th July 2009, 18:52
  5. Pic16f886
    By Larry in forum mel PIC BASIC Pro
    Last Post: - 10th October 2008, 23:40
