Not strictly GPS but Magnetometer HMC5883L (Electonic compass and 16f818)
Results 1 to 6 of 6
    Default Re: Not strictly GPS but Magnetometer HMC5883L (Electonic compass and 16f818)
    we need the raw readx and ready values when the module is held level and :-
    1 facing magnetic north
    2 south
    3 east
    4 west
    these readings should represent maxima and minima also. if not this setup is not going to work
    if the min- max readings are not the full 4096 range then the existing 360 degree scaling will be way off' and will need to allowed for .
    you may also need to "normalise" the readings in some way to compensate for varying field strengths (or adjust the gain).
    the reading results may need to rotated by a fraction of pi to achieve proper orientation (ie to make 0 equate to north).
    Are you using one of the break-out boards, GY0281 or GY282? George
    May 2012
    Merseyside, UK
    Hi George
    Yes a GY-271 I Think...
    May 2012
    Merseyside, UK
    Hi Richard
    I am seeing what you are suggesting.... My problem is I have no time to really play.
    Plus I non to good at software.... Will check out what you are suggesting ASAP
    BR
    Andy
  1. HMC5883L Magnetometer chip Possibilities.
    By andybarrett1 in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2015, 16:15
  2. 16f818 from 16f628a
    Last Post: - 27th August 2014, 08:31
  3. HMC5883L code please
    By trilian in forum mel PIC BASIC Pro
    Last Post: - 21st August 2014, 17:12
  4. 3 axis digital compass sensor HMC5883L
    By ScaleRobotics in forum General
    Last Post: - 8th June 2014, 23:19
  5. Interface for 16f818
    By davekav in forum Serial
    Last Post: - 17th April 2008, 12:33
