16f883 sleeping mode
Results 1 to 6 of 6
    Jan 2012
    Grid EN19MV
    Default Re: 16f883 sleeping mode
    Here's some code from when I needed a 16f886 to sleep until PORTB.0 went low. You should be able to adapt it. I should mention that I am self-taught at BASIC so there's probably a better way to do this:
    #CONFIG __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    DEFINE NO_CLEARWDT 1 'NO WATCHDOG TIMER
    DEFINE OSC 8  'LETS PBP KNOW THE OSCILLATOR IS RUNNING AT 8MHz
    OSCCON = %01110001 '8 MHz INTERNAL OSCILLATOR, INTERNAL OSCILLATOR IS USED FOR SYSTEM CLOCK
    DISABLE 'NO INTERRUPTS, NO DEBUG COMMENT THIS OUT FOR INTERRUPTS
    ANSEL = 0 'PORTA ALL DIGITAL
    ANSELH = 0 'PORTB ALL DIGITAL
    OPTION_REG = 0 'PORT B PULLUPS ENABLED
    WPUB = %01111111 'PULL UPS ENABLED ON PORTB 0-6
    INTCON = 0 'INTERRUPTS DISABLED
    IOCB = %00000001 'PORTB.0 INTERRUPT ON CHANGE ENABLED
    TRISA = 0 'PORTA ALL OUTPUTS
    TRISB = %01111111 'B7 OUTPUT, ALL THE OTHERS INPUTS
    TRISC = 0 'PORTC ALL OUTPUTS
    DUMMY VAR BYTE
    <irrelevant code here>
    INTCON = %00001000 'PORTB CHANGE INTERRUPT ENABLED GIE *NOT* ENABLED
    NAP 0 'NAP (ENTER VERY LOW POWER MODE) FOR ABOUT 18mS.  SINCE THE WATCHDOG TIMER IS NOT ENABLED,
             'THE PROCESSOR WOULD NAP FOREVER, EXCEPT FOR THE FACT THAT THE 'INTERRUPT-ON-STATE-CHANGE'
             'BIT FOR PORTB.0 (MASTER SWITCH) IS ENABLED. THIS MEANS THAT A CHANGE ON THE MASTER SWITCH
             '(OFF TO ON) WILL GENERATE AN INTERRUPT.  HOWEVER, THE GLOBAL INTERRUPT ENABLE BIT IS *NOT*
             'SET.  THIS MEANS A *REAL* INTERRUPT WILL NOT BE GENERATED.  THE PROCESSOR WILL NOT JUMP TO THE INTERRUPT
             'ROUTINE, AND WILL, INSTEAD, EXECUTE THE NEXT INSTRUCTION AFTER THE NAP - IN OTHER WORDS, CONTINUE
             'THE MAIN LOOP WHERE THE NEW STATE OF THE MASTER SWITCH WILL BE CAUGHT BY THE IF STATEMENT.  THIS
             'HAS THE EFFECT OF SHUTTING THE PROCESSOR DOWN (ESSENTIALLY) UNTIL THE MASTER SWITCH IS TURNED ON
             'AGAIN - SAVING THE VEHICLE'S BATTERY IF THE MAIN POWER SWITCH IS ACCIDENTALLY LEFT ON.  OPERATION
             'OF ANY OF THE OTHER SWITCHES WILL NOT CAUSE THE ABOVE TO HAPPEN AS THEIR ENABLE BITS IN THE IOCB
             'REGISTER HAVE NOT BEEN SET.
    DUMMY = PORTB 'READ PORTB TO CLEAR THE MISMATCH THAT GENERATED THE INTERRUPT
    INTCON = 0 'INTERRUPTS OFF AGAIN
    -Stephen Hawking
    Thanks for your help. Best Regards.
  1. LCD's and Sleeping Pics
    By andybarrett1 in forum mel PIC BASIC Pro
    Last Post: - 1st June 2015, 18:18
  2. 16f883
    By Meriachee in forum mel PIC BASIC Pro
    Last Post: - 10th September 2009, 00:45
  3. 16F883 Code Verify Problem
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 11:47
  4. 16F883/886 Help
    By plyrathrt in forum General
    Last Post: - 18th August 2008, 08:54
  5. Waking a sleeping PIC
    By anj in forum mel PIC BASIC Pro
    Last Post: - 19th May 2005, 01:51
