Need help getting started.
Results 1 to 4 of 4
Threaded View
  1. #3
    Default Re: Need help getting started.
    This ought to get you started if you are using PBP 3.
    #IF __PROCESSOR__ = "16F690"
    #config
    cfg1 = _INTRC_OSC_NOCLKOUT  ; Internal oscillator
    cfg1&= _WDT_OFF             ; Watch Dog Timer disabled
    cfg1&= _PWRTE_OFF           ; Power-up Timer disabled
    cfg1&= _MCLRE_ON            ; Master Clear Reset enabled
    cfg1&= _CP_OFF              ; Program Code Protection is disabled
    cfg1&= _CPD_OFF             ; Data Code Protection is disabled
    cfg1&= _BOD_OFF             ; Brown-out Detect disabled
    cfg1&= _IESO_OFF            ; Internal External Switchover mode is disabled
    cfg1&= _FCMEN_OFF           ; Fail-safe Clock Monitor is disabled
     __CONFIG  cfg1             ; Set the configuration bits
    #else
        #MSG "Wrong microcontroller selected!"
    #endif
    ANSEL = %00000000
    ;CMCON0 = %00000111
    ;CMCON1 = %00000010
    PORTC = 0
    ANSELH=0
    ADCON0 = 0
    ADCON1 = 0
    BTW I use those same demo boards.
  1. Help Getting Started
    By doggitz in forum mel PIC BASIC Pro
    Last Post: - 25th August 2009, 21:30
  2. getting started
    By cunninghamjohn in forum mel PIC BASIC Pro
    Last Post: - 15th November 2008, 18:42
  3. Getting started... again...
    By Neosec in forum mel PIC BASIC Pro
    Last Post: - 31st May 2008, 02:09
  4. getting started
    By rmow in forum Schematics
    Last Post: - 21st March 2008, 03:06
  5. How did you get started .....
    By keithdoxey in forum General
    Last Post: - 13th April 2007, 19:29
