usart-bluetooth problem
Results 1 to 33 of 33
    Dec 2010
    Default Re: usart-bluetooth problem
    Unless you have successfully used Putty for this application before, I think it might not be the best choice. It has default configuration and protocols that will give you trouble. Instead search for and download the free "Bray's terminal.exe". I've used version 1.9b for this and many other similar applications, after giving up on Putty. It's a much better replacement for Hyperterminal - even if you still have an OS with Hyperterminal.
    to test bt link, program a pic to serout some data say "1,2,3,4 a,b,c,d" every second or so to the bt module. the baud from pic to module should match but the bt to pc link makes its own rate. I'm sure you found the com port created by the bt device through the SPP - serial port profile mode seen in bt settings on win8. on my device bt set up 2 com ports of which one works the link. with that you can try/check for the correct T and R connections at pic end.
    I put hyperterm on my win8 just copy pasted 2 files
Size:  54.8 KBName:  Capture.JPG
    Dec 2010
    I repeat...
    Quote Originally Posted by Charlie View Post
  1. Bluetooth headset for non bluetooth devices?
    By Normnet in forum Bluetooth
    Last Post: - 26th September 2015, 12:22
  2. USART SPI problem !
    By TripleS in forum mel PIC BASIC Pro
    Last Post: - 16th October 2007, 23:09
  3. USART Problem , but don't know where, in pc? or in PIC?
  4. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 18:56
  5. PIC16F688 USART problem
    By Kees Reedijk in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2006, 05:59
