usart-bluetooth problem
Results 1 to 33 of 33
    Dec 2014
    Default Re: usart-bluetooth problem
    henrik, i did what you said but nothing has changed- neither led nor data. what do you think? can it be about hardware?
    Then I'm afraid it's back to basics....and of course it can be a hardware issue.
    Is the PIC actually running and if so is it running at the correct speed?
    Do a blink-a-led program and verify that first.
    Then start focusing on the serial comms but do it with a wired connection first. Once you have THAT going, switch to your Bluetooth module. Right now there are SO many things that can be wrong.....
    * PIC is not running at the correct speed.
    * Hardware problem between PIC and Bluetooth module.
    * Wrong baudrate between PIC and Bluetooth.
    * Wrong baudrate on the virtual COM port,
    * Wrong settings in PUTTY.
    You get the idea.....
  1. Bluetooth headset for non bluetooth devices?
    By Normnet in forum Bluetooth
    Last Post: - 26th September 2015, 12:22
  2. USART SPI problem !
    By TripleS in forum mel PIC BASIC Pro
    Last Post: - 16th October 2007, 23:09
  3. USART Problem , but don't know where, in pc? or in PIC?
  4. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 18:56
  5. PIC16F688 USART problem
    By Kees Reedijk in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2006, 05:59
