In the above loop you are writing commands over and over again. I would not expect anything to display. I have to assume the supply to this display needs to be 5v (according to the paper you received from your friend). The connections should look like this with 5v
Also change the address to $7C again according to the data sheet i found.
I found this data sheet at http://www.farnell.com/datasheets/1669635.pdfCode:I2C interface It just only could write Data or Instruction to ST7032 by the IIC Interface. It could not read Data or Instruction from ST7032 (except Acknowledge signal). SCL: serial clock input SDA: serial data input Slaver address could only set to 0111110, no other slaver address could be set
The pinouts are the same as your display
give the above a try, that a look at the data sheet.Code:'**************************************************************** '* Name : UNTITLED.BAS * '* Author : Dave Cutliff * '* Notice : Copyright (c) 2014 Use at your own risk * '* : All Rights Reserved * '* Date : 12/29/2014 * '* Version : 1.0 * '* Notes : * '* : * '**************************************************************** #CONFIG __CONFIG _CONFIG1, _FCMEN_OFF & _FOSC_INTOSC & _WDTE_OFF & _MCLRE_OFF & _CP_ON & _IESO_OFF & _BOREN_OFF & _PWRTE_OFF __CONFIG _CONFIG2, _PLLEN_OFF & _STVREN_OFF & _LVP_OFF #ENDCONFIG OSCCON = %01101010 'sets the internal oscillator to 4Mhz TRISA = %00000000 TRISC = %00000000 ANSELA = %00000000 ANSELC = %00000000 OPTION_REG.7 = 0 SCL VAR PORTC.0 SDA var PORTC.1 Reset var PORTC.2 'could tie reset pin to vdd through 10K resistor pause 100 HIGH Reset 'OPF1 = 0 goto StartProgram '******************************************************************************** '=============Initializing LCD========== ST7036Init: I2CWRITE PORTC.1, PORTC.0,$7C,[$00,$38] PAUSE 10 I2CWRITE PORTC.1, PORTC.0,$7C,[$00, $39,$14,$79,$50,$6C,$0C,$01,$06] ' Return '******************************************************************************** startProgram: gosub ST7036Init I2CWRITE PORTC.1, PORTC.0,$7C,[$40,$48,$65,$6c,$6c,$6f] ' Hello IdleLoop: ' could blink an led here goto Idleloop
Good luck
