I2C LCD
Results 1 to 40 of 47
Thread: I2C LCD
    Default Re: I2C LCD
    I think the LCDs that googled up for TM202 were Tienma. None of them were TM202T or S. It looks like these are custom made, specs could be anything.
    I suggest contacting Tienma and asking for a datasheet.
    Mar 2008
    Gerogetown, Texas
    Default Re: I2C LCD
    As an outside chance change your pullup resistors to 4.7K, I have never used 1k. The contrast is set in the initialization of the display. I do not think you can change it on the fly.
    And lastly give this a try
    '*  Author  : Dave Cutliff                                      *
    '*  Notice  : Copyright (c) 2014 Use at your own risk           *
    '*  Date    : 12/29/2014                                        *
            __CONFIG _CONFIG1, _FCMEN_OFF & _FOSC_INTOSC & _WDTE_OFF & _MCLRE_OFF & _CP_ON & _IESO_OFF & _BOREN_OFF & _PWRTE_OFF
            __CONFIG _CONFIG2, _PLLEN_OFF & _STVREN_OFF & _LVP_OFF
    OSCCON = %01101010   'sets the internal oscillator to 4Mhz
    TRISA  = %00000000
    TRISC  = %00000000
    ANSELA = %00000000
    ANSELC = %00000000
    OPTION_REG.7 = 0
    SCL   VAR PORTC.0
    SDA   var PORTC.1
    Reset    var PORTC.2     'could tie reset pin to   vdd through 10K resistor
    HIGH Reset
    'OPF1 = 0
    goto StartProgram
    '=============Initializing LCD==========
    ST7036Init:
    I2CWRITE PORTC.1, PORTC.0,$78,[$00,$38, $39,$14,$79,$50,$6C,$0C,$01,$06] '
    startProgram:
    gosub  ST7036Init
    I2CWRITE PORTC.1, PORTC.0,$78,[$40,$48,$65,$6c,$6c,$6f] ' Hello
    IdleLoop:
          ' could blink an led here
    goto Idleloop
    Default Re: I2C LCD
    Quote Originally Posted by DaveC3 View Post
    As an outside chance change your pullup resistors to 4.7K, I have never used 1k. ...
    Yup, from the manual:
    The I2C clock and data lines should be pulled up to Vcc with a 4.7K
    Could this be an issue?
    Transfer on the I2C bus can be paused by the receiving device by its holding the clock line low (not supported on 12-bit core PIC MCUs). To enable this the following DEFINE should be added to the program:
    DEFINE I2C_HOLD 1
    EDIT: I would try one last thing with Dave's code, add PAUSE 250 before every write to the LCD, just to eliminate that possibility.
  1. I2C lcd ( arduino ) with PICBASIC, help
    Last Post: - 10th September 2014, 19:00
  2. I2C variable to LCD
    By pointjohn in forum Serial
    Last Post: - 19th October 2011, 09:53
  3. I2C to LCD display
    By Ron Marcus in forum Serial
    Last Post: - 29th December 2007, 15:53
  4. Need cheap i2c LCD for 16F877a
    By CodeShredder in forum mel PIC BASIC Pro
    Last Post: - 6th December 2006, 02:25
Members who have read this thread : 4
