I2C LCD
Results 1 to 40 of 47
Thread: I2C LCD
    Jan 2014
    Default Re: I2C LCD
    Quote Originally Posted by DaveC3 View Post
    To inilalize this display wyou need to write something like this
    high RESET
    pause 10
    low RESET
    pause 10
    high RESET
    I2CWRITE datapin, clockpin,$7C[$80,$57,$80,$6C,$80,$01,$80,$02]
    before you can write to the display
    I2CWRITE datapin, clockpin,$7C[$80,$80,$40,$48,$45,$$4C,$4c,$4F]  'HELLO
    I do not have a display to test so not sure if this will work, but this is what I would start with, I took the code from the data sheet.
    Thx Dave, I tried but nothing!
    I tried a code for 7036i controller, with V0 connected to Vdd , but I feel that somewhere I'm wrong in DEFINE LCD .
    I know that your help eat a lot of time, but if somebody have a free time to read in datasheet and help me, I'll appreciate!
    Datasheet 7036i : http://www.datasheetarchive.com/dlma...DSA-621251.pdf
    Code :
    'PIC 16F1824
            __CONFIG _CONFIG1, _FCMEN_OFF & _FOSC_INTOSC & _WDTE_OFF & _MCLRE_OFF & _CP_ON & _IESO_OFF & _BOREN_OFF & _PWRTE_OFF
            __CONFIG _CONFIG2, _PLLEN_OFF & _STVREN_OFF & _LVP_OFF
    OSCCON = %01101010   'sets the internal oscillator to 4Mhz
    TRISA  = %00000000
    TRISC  = %00000000
    ANSELA = %00000000
    ANSELC = %00000000
    OPTION_REG.7 = 0
    WPUA = %00000000
    WPUC = %00000011
    PORTA = 0
    PORTC = 0
    SCL   VAR PORTC.0
    SDA   var PORTC.1
    RS    var PORTC.2
    symbol mode = $7C
    RS = 0
    'OPF1 = 0 ; OPF2 = 0 . => BON=0, FON=1. => Vout=Vin (pag50 datasheet)
    '=============Initializing by Instruction==========pag 39 datasheet
    'CLEAR LCD --------------pag 28 datasheet
    I2CWRITE sda, scl,mode,[$01]
    pause 10
    'ENTRY MODE SET----------
     I2CWRITE sda, scl,mode,[$07] 'cursor/blink moves to right and DDRAM address is increased by 1.
     pause 10
    'FUNCTION SET------------pag 30 datasheet
    I2CWRITE sda, scl,mode,[$38] ' 8 bit, 2 lines, font normal, instruction table 0
    pause 10
    'CURSOR DISPLAY------------pag 29 datasheet
    I2CWRITE sda, scl,mode,[$14]
    pause 10
    'INTERNAL OSC------------pag 35 datasheet
    I2CWRITE sda, scl,mode,[$14] ' 1/5 BIAS , 130Hz/5v
    pause 10
    'CONTRAST SET------------pag 37 datasheet
    I2CWRITE sda, scl,mode,[$7F]
    pause 10
    'POWER/ICON/CONTRAST------pag 36 datasheet
    I2CWRITE sda, scl,mode,[$5B] 'ICON=ON, BON = OFF , contrast $03
    pause 10
    'FOLLOWER CONTROL-------pag 37 datasheet
    I2CWRITE sda, scl,mode,[$6F] 'FON=1 ..set is correct ??
    pause 10
    'DISPLAY ON------------- pag 29 datasheet
    I2CWRITE sda, scl,mode,[$0E] 'display ON, cursor ON, blink OFF
    pause 10
    RS = 1
    I2CWRITE SDA,SCL,mode,["HELLO"] 'print on the first line
    Mar 2008
    Gerogetown, Texas
    Default Re: I2C LCD
    Try this, initalization based on an arduino sketch
    'PIC 16F1824
    TRISA  = %00000000
    TRISC  = %00000000
    ANSELA = %00000000
    ANSELC = %00000000
    OPTION_REG.7 = 0
    WPUA = %00000000
    WPUC = %00000011
    PORTA = 0
    PORTC = 0
    SCL   VAR PORTC.0
    SDA   var PORTC.1
    RS    var PORTC.2
    symbol mode = $7C
    RS = 0
    I2CWRITE PORTC.1, PORTC.0,$7C,[$00] 'send command to display
    'FUNCTION SET 0 and 1 ------------pag 30 datasheet
    I2CWRITE PORTC.1, PORTC.0,$7C,[$38] ' Function set - 8 bit, 2 line display 5x8, inst table 0
    pause 10
    I2CWRITE PORTC.1, PORTC.0,$7C,[$39] ' Function set - 8 bit, 2 line display 5x8, inst table 1
    pause 10
    I2CWRITE PORTC.1, PORTC.0,$7C,[$14] ' 1/5 BIAS , 130Hz/5v
    I2CWRITE PORTC.1, PORTC.0,$7C,[$73]
    I2CWRITE PORTC.1, PORTC.0,$7C,[$5E] 'ICON=ON, BON = OFF , contrast $03
    I2CWRITE PORTC.1, PORTC.0,$7C,[$6D] 'FON=1 ..set is correct ??
    pause 10
    I2CWRITE PORTC.1, PORTC.0,$7C,[$0C] 'display ON, cursor ON, blink OFF
    I2CWRITE PORTC.1, PORTC.0,$7C,[$01]
     I2CWRITE PORTC.1, PORTC.0,$7C,[$06] 'cursor/blink moves to right and DDRAM address is increased by 1.
    RS = 1
    I2CWRITE PORTC.1,PORTC.0,$7C,["HELLO"] 'print on the first line [ I am not sure this line will work]
    Can you include a high res picture of your display?
    Mar 2008
    Gerogetown, Texas
    Default Re: I2C LCD
    try this
    'PIC 16F1824
    TRISA  = %00000000
    TRISC  = %00000000
    ANSELA = %00000000
    ANSELC = %00000000
    OPTION_REG.7 = 0
    WPUA = %00000000
    WPUC = %00000011
    PORTA = 0
    PORTC = 0
    SCL   VAR PORTC.0
    SDA   var PORTC.1
    RS    var PORTC.2
    symbol mode = $7C
    RS = 0
    I2CWRITE PORTC.1, PORTC.0,$7C,[$78] 'slave
    pause 10
    pause 10
    pause 10
    RS = 1
    I2CWRITE PORTC.1, PORTC.0,$7C,[$40] 'Write to display RAM
    Mar 2008
    Gerogetown, Texas
    Default Re: I2C LCD
    or try this,
    TRISA  = %00000000
    TRISC  = %00000000
    ANSELA = %00000000
    ANSELC = %00000000
    OPTION_REG.7 = 0
    SCL   VAR PORTC.0
    SDA   var PORTC.1
    Reset    var PORTC.2     'could tie reset pin to   vdd through 10K resistor
    HIGH Reset
    'OPF1 = 0
    goto StartProgram
    '=============Initializing LCD==========
    ST7036Init:
    I2CWRITE PORTC.1, PORTC.0,$78,[$00,$38] ' Function set - 8 bit, 2 line display 5x8, inst table 0
    pause 10
    I2CWRITE PORTC.1, PORTC.0,$78,[$00,$39] ' Function set - 8 bit, 2 line display 5x8, inst table 1
    pause 10
    I2CWRITE PORTC.1, PORTC.0,$78,[$00,$14,$73,$5E,$6D,$0C,$01,$06] '
    startProgram:
    gosub  ST7036Init
    I2CWRITE PORTC.1, PORTC.0,$78,[$40,$48,$65,$6c,$6c,$6f] ' Hello
    IdleLoop:
          ' could blink an led here
    goto Idleloop
  1. I2C lcd ( arduino ) with PICBASIC, help
    Last Post: - 10th September 2014, 19:00
  2. I2C variable to LCD
    By pointjohn in forum Serial
    Last Post: - 19th October 2011, 09:53
  3. I2C to LCD display
    By Ron Marcus in forum Serial
    Last Post: - 29th December 2007, 15:53
  4. Need cheap i2c LCD for 16F877a
    By CodeShredder in forum mel PIC BASIC Pro
    Last Post: - 6th December 2006, 02:25
Members who have read this thread : 4
