I do not see RESET set to any value. Portc is 0. Most LCDs I have work with the reset line needs to be high. (except if you are resetting) I could not find a data sheet so not sure about your display.
Yeah, couldn't find anything either.
Try adding a PAUSE 250 before writes to give time to lcd to initialize.
I am just curious. Did you manage to run LCD with the pinout from MIDAS? I mean the pinout you mentioned at beginning of this thread.
What manual? Do you have a link?2C = $7C 'ADDRESS FROM MANUAL ??
Now I understand arrays variable. Thank you for your patience and explanation!
