I2C LCD
Results 1 to 40 of 47
Thread: I2C LCD
    Apr 2011
    Welches, Oregon
    Default Re: I2C LCD
    You can start by seeing the "squares" where the characters will appear darken. Once you get something going - adjust to taste.
    Mar 2008
    Gerogetown, Texas
    Default Re: I2C LCD
    I do not see RESET set to any value. Portc is 0. Most LCDs I have work with the reset line needs to be high. (except if you are resetting) I could not find a data sheet so not sure about your display.
    Default Re: I2C LCD
    Yeah, couldn't find anything either.
    Try adding a PAUSE 250 before writes to give time to lcd to initialize.
    zoltanh's Avatar
    zoltanh Guest
    Default Re: I2C LCD
    I am just curious. Did you manage to run LCD with the pinout from MIDAS? I mean the pinout you mentioned at beginning of this thread.
    Default Re: I2C LCD
    2C = $7C 'ADDRESS FROM MANUAL ??
    What manual? Do you have a link?
    Jan 2014
    Default Re: I2C LCD
    Now I understand arrays variable. Thank you for your patience and explanation!
  1. I2C lcd ( arduino ) with PICBASIC, help
    Last Post: - 10th September 2014, 18:00
  2. I2C variable to LCD
    By pointjohn in forum Serial
    Last Post: - 19th October 2011, 08:53
  3. I2C to LCD display
    By Ron Marcus in forum Serial
    Last Post: - 29th December 2007, 14:53
  4. Need cheap i2c LCD for 16F877a
    By CodeShredder in forum mel PIC BASIC Pro
    Last Post: - 6th December 2006, 01:25
