There's a lot of schematics for "gang multiple pic programmer schematic circuit".
Which is better I couldn't say. This one is neat, but I'd use zif sockets from ebay instead of those pogo thingies.
https://www.sparkfun.com/news/743
How about having Digikey pre-program them for you?
I don't know if this will work for ICSP but I have paralleled up to 10 DIP chips and ran a cable to my programmer socket. It programs all of them at the same time.
Peter, did you have verify enabled?
Yes Robert. I use a Picstart + from Mplab. It always verifies after programming. And after paralleling the chips and programming them, they were immediately installed on the circuit boards and tested OK. I must admit that it isn't perfect. Occasionally I would find some PICs that didn't work and had to reprogram them. The easiest way to try this is to stack the chips one on top of the other so that all the pins are in parallel. Then stick the bottom chip in the programmer. If you stack say 10 PICs, and there is a loose connection between the 5th and 6th chip, then the chain is broken and the top 5 won't be programmed. Try it with a couple. It works.
Here is what I use to program multiple chips... I can do one chip in about 5 sec
>drop in a new chip in the ZIF socket
>clamp the ZIF socket
>hit Enter to program
>release the ZIF lever
>drop the programmed chip into a static safe bag (I use a metalized static bag opened up on the counter and just tip the programmer over to drop the chip into the bag)
>repeat...
All in around 5 seconds
Just get yourself an appropriately sized ZIF (zero insertion force) socket and a little bit of perf board and a header strip or whatever you need for your programmer and go to town
Dwight
Does the PICKit2 require power from the pcb?
