Elapsed timer not working as expected at 64MHz
Results 1 to 40 of 56
    Default Re: Elapsed timer not working as expected at 64MHz
    debug T1PS and TimerConst to see what's going on would be a good start
    Roger, oveur.
    Feb 2012
    PERTH AUSTRALIA
    yep there was no elapsed-18_k22
    seems to me the easiest way to restore correct function for "ticks" when the post scaler is in use is to move the ticks loop inside the post scale loop , no extra vars no extra overhead
    ClockCount:
    @ RELOAD_TIMER                   ; Reload TIMER1
        T1Post = T1Post + 1
        IF T1Post = T1PS THEN
          T1Post = 0
         Ticks = Ticks + 1
            IF Ticks = 100 THEN
               Ticks = 0
               Seconds = Seconds + 1
               SecondsChanged = 1
               IF Seconds = 60 THEN
                  Seconds = 0
                  Minutes = Minutes + 1
                  MinutesChanged = 1
               IF Minutes = 60 THEN
                  Minutes = 0
                  Hours = Hours + 1
                  HoursChanged = 1
               IF Hours = 24 THEN
                  Days = Days + 1
                  DaysChanged = 1
                  Hours = 0
    @ INT_RETURN                     ; Restore context and return from interrupt
    I can only think that there was a reason why Darrel did it as he did. The dude could probably code this stuff while playing ping pong; the Bruce Lee of PBP and ASM.
    There's more than one way to solve a problem, he probably took the one that worked for all PICs (until the K22 series came along). And even that he's solved the problem, it just wasn't widely known. I can only think he had greater concerns on his mind. Can you imagine how much of a headache it must have been tracking the new releases versus his routines? Makes me appreciate and miss him even more.
    I now fear the day when Microchip releases a new product line. I love the K22 like I loved the 16F628 and 16F877, I'm not changing unless I'm forced to change.
    Shoot, I might even stay on PBP 2.6. LOL
    it has nothing to do with the k22's its the problem exists whenever the T1PS value is >1 on any chip
    its all to do with the way he implemented the post scaling , the loops are inside out . its no bigie to fix . its only apparent if you need to use "ticks" .
    imho most of the time using ticks is pointless by the time you process the reading and then display it it's already meaningless and out of date . if you want to time events to such accuracy trigger times need to be allowed for and properly sync'ed , there are much better ways
    ps
    the k22 interrupt vagaries are a separate issue and unrelated to ticks not being 100th's of a sec
    its only apparent if you understand what's going on .
    There, fixed it for you. LOL
    I never dealt with timer guts before. I always thought pre-scaling and post-scaling were what the fish looked like when my mom prepared them.
    Oh and I don't like fish.
    you have to toggle your led at the correct place in the loop
    the interrupt runs at 4x the speed required (because of high fosc not chip type ) for timing so the post scaler divides it by 4
    ClockCount:
    T1Post = T1Post + 1
    Robert toggle your pin here eg latd.0=!latd.0 for 2.5mS
    T1Post = 0
    Ticks = Ticks + 1
    Robert toggle your pin here eg latd.1=!latd.1 for 10mS
    IF Ticks = 100 THEN
    Ticks = 0
    SecondsChanged = 1
    Seconds = 0
    MinutesChanged = 1
    Minutes = 0
    Hours = Hours + 1
    HoursChanged = 1
    IF Hours = 24 THEN
    Days = Days + 1
    DaysChanged = 1
    Hours = 0
    ...imho most of the time using ticks is pointless by the time you process the reading and then display it it's already meaningless and out of date . if you want to time events to such accuracy trigger times need to be allowed for and properly sync'ed , there are much better ways
    ps
    I disagree. This is the first time I have a specialized need for a timer and it requires knowing how long a tick really is. I want to debounce using interrupts, so I press a button, look how long it takes for the contact to close and open again, take an arbitrary average and add maybe 25%, that's my debounce in mSeconds.
    I know others use timers in what I consider a more complicated way, I have no clue how a preload value works and can never remember if the timer counts up or down from there (I have a hard time remembering little details like that). To them it's easier, I prefer the elapsed timer approach.
    I turn a LED on and off, check the interval on the Saleae probe (I should get a commission every time I typed that), and that's it. Ticks=10mS is stuck in my brain ever since I first saw it on Darrel's include. I just count the ticks until I get my interval.
    When you think about it, if we were that concerned with accuracy, we'd program in assembler.
    I started by making my version of the Elapsed include and adding 2 variables at the end of the timer calc:
    ' -------------- calc timer reload Constants -------------------------------
    T1PS = 1                             ; start with 1:1 postscaler
    TimerConst = ((OSC*1000000)/4/100)   ; how many timer ticks will it take
      while TimerConst > 65400           ; if it's more than the timer can count
    T1PS = T1PS * 2                      ;   double the postscaler
    TimerConst = TimerConst / 2          ;   halve the count
      endw
    TimerConst = 65536 - TimerConst + 8  ; final reload value
    ; ---------------------------- DEBUG SCALER --------------------------------
    DebugT1PS = T1PS
    DebugTC = TimerConst
    ; xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    Before Main of my program I added:
    DebugT1PS CON EXT
    DebugTC   CON EXT
    Right now I'm wiring up a LCD to display the 2 variables.
    Am I on the right track to look at them?
    I've never tried to display something from inside Darryl's includes before. My plan was to copy them into 2 words and then displaying the lower and upper bytes on the LCD.
    probably not if yours fails try this
    DISABLE DEBUG
    ; syntax =     Handler  IntSource,        Label, Type, ResetFlag?
    DEFINE  Elapsed_Handler  TMR1_INT,  _ClockCount,  asm,  yes
    ; the above define can be used in the INT_LIST macro, if desired (optional)
    Ticks            VAR BYTE   ; Counts timer Overflows
    T1Post           VAR BYTE   ; Timer1 postscaler
    Seconds          VAR BYTE
    Minutes          VAR BYTE
    Hours            VAR BYTE
    Days             VAR WORD
    DebugT1PS     var byte
    DebugTCL       var byte
    DebugTCh       var byte
    SecondsChanged   VAR BIT    ; idicates that the value has changed
    MinutesChanged   VAR BIT
    HoursChanged     VAR BIT
    DaysChanged      VAR BIT
    GOSUB ResetTime             ; initialize the Elapsed Timer
    Goto OverElapsed            ; skip over the routines
      endw
     _DebugT1PS =T1PS
     _DebugTCH=TimerConst /256
     _DebugTCL = TimerConst - _DebugTCH*256
    ; -----------------  ADD TimerConst to TMR1H:TMR1L -------------------------
    ADD2_TIMER   macro
    Actually, it worked.
    I deleted my debug include 'cause I can work without it.
    ;T1PS        CON EXT    ' Already defined in include
    TimerConst  CON EXT
    varT1PS   var word
    varTC     var word
        varT1PS = T1PS
        varTC   = TimerConst
        Lcdout $fe, 1, "Timer 1"
        Lcdout $fe, $94, "PS:", BIN8 varT1PS.byte1, " ", BIN8 varT1PS.byte0
        Lcdout $fe, $D4, "TC:", BIN8 varTC.byte1, " ", BIN8 varTC.byte0
    MainProgram:
    And I get:
    PS:00000000 00000001
    TC:01100011 11001000 <--- Dec=25544
    EDIT: Woooops, still using OSC 16, BRB.
    OSC 64 (16 + PLL)
    PS:00000000 00000100 <--- Dec=4
    I had same results manually this afternoon.
    ok next whats in T1CON ?
    Looking at the datasheet for 18F44K22, timer 1 has a 2 bit prescaler.
    4 (100) takes 3 bits.
    Gonna try timer 2.
    13.0 TIMER2/4/6 MODULE p.175
    • 8-bit Timer and Period registers (TMRx and PRx,
    respectively)
    • Readable and writable (both registers)
    • Software programmable prescaler (1:1, 1:4, 1:16)
    • Software programmable postscaler (1:1 to 1:16)
    EDIT: Darn, DT Elapsed include only has Timer1...
    Was looking at T1CON register and noticed this:
    TxCKPS<1:0>: Timer1/3/5 Input Clock Prescale Select bits
    11 = 1:8 Prescale value
    10 = 1:4 Prescale value
    01 = 1:2 Prescale value
    00 = 1:1 Prescale value
    So that is 2 bits.
    bit 7-6 TMRxCS<1:0>: Timer1/3/5 Clock Source Select bits
      11 =Reserved. Do not use.
      10 =Timer1/3/5 clock source is pin or oscillator:
        If TxSOSCEN = 0:
          External clock from TxCKI pin (on the rising edge)
        If TxSOSCEN = 1:
          Crystal oscillator on SOSCI/SOSCO pins
      01 =Timer1/3/5 clock source is system clock (FOSC)
      00 =Timer1/3/5 clock source is instruction clock (FOSC/4)
    bit 5-4 TxCKPS<1:0>: Timer1/3/5 Input Clock Prescale Select bits
    bit 3 TxSOSCEN: Secondary Oscillator Enable Control bit
      1 = Dedicated Secondary oscillator circuit enabled
      0 = Dedicated Secondary oscillator circuit disabled
    bit 2 TxSYNC: Timer1/3/5 External Clock Input Synchronization Control bit
        TMRxCS<1:0> = 1X
      1 = Do not synchronize external clock input
      0 = Synchronize external clock input with system clock (FOSC)
        TMRxCS<1:0> = 0X
      This bit is ignored. Timer1/3/5 uses the internal clock when TMRxCS<1:0> = 1X.
    bit 1 TxRD16: 16-Bit Read/Write Mode Enable bit
      1 = Enables register read/write of Timer1/3/5 in one 16-bit operation
      0 = Enables register read/write of Timer1/3/5 in two 8-bit operation
    bit 0 TMRxON: Timer1/3/5 On bit
      1 = Enables Timer1/3/5
      0 = Stops Timer1/3/5
        Clears Timer1/3/5 Gate flip-flop
    T1CON=00000000
    ITS NOT using the prescaler those bits need to be 00 ie 1:1
    @64mhz with a preload of 25544 you get a tmr1 int every 2.5mS dt's int routine inc's the tips counter till its 4 then inc's the elapsed time clock I count ie once every 10mS
    next step after confirming t1con is ok is to toggle a pin in the int routine as per what Sheldon suggested and verify 2.5mS ints are occurring
    In the Elapsed include:
      endw
    Darryl talks about a post-scaler. Timers 1, 3 and 5 have none for a 18F44K22?
    Neither does Timer 0, only Timers 2,4 and 6 have pre and post-scalers.
    t1con looks good should be 0 or 1 (on or off) depending on what the int routine is up to
  1. I2CRead & I2CWrite not working as expected
    Last Post: - 27th October 2021, 18:36
  2. PORTB.3 Input not working as expected.
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 5th March 2013, 09:58
  3. Elapsed Timer Demo
    Last Post: - 29th October 2012, 17:39
  4. SPWM and Elapsed Timer
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 8th May 2008, 03:16
  5. DT Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 23:17
