Hi Robert,
The first piece of code is executed by the assembler at the time the code is built. It doesn't execute when the PIC actually runs so there's no WORD size limit at play as far as I know.
The second piece you've marked in red is of course run time code but by the TimerConst should be less than 65400 so no problem.
With that said something is apparently not working as expected. Darrels code, relies on you having DEFINE OSC xx correctly. It's easy enough to have a 16MHz clock with the corresponding DEFINE and then enable the PLL to get 64MHz but forget to change to DEFINE OSC 64.
