Boost converter (sepic)
Results 1 to 2 of 2
    Sep 2006
    Default Boost converter (sepic)
    Hello,
    Anyone has an algorithm for a sepic boost converter in picbasic ?
    I have written a function that increments by one the duty cycle, but after further testing it is not a fats way to reach the necessary output. I have a voltage check on the output only (12v) and the duty cycle varies according to the output .
    here is the code I have:
    VoltageCheck:
         ADCON0.2 = 1			'Start Conversion
         adcin 4,VoltageInput
        If voltageInput < voltageREF then        ' voltageREF is 75 for 12v dc
            VoltageDiff = VoltageREF - VoltageInput     '=150+(150-115)=185
            DutyCycle = voltageREF + ( voltageREF - VoltageDiff)
            DutyCycle = DutyCycle/255 *100
            HPWM 1,DutyCycle,Frequency         'channel, dutycycle, frequency
            pause 20
        If voltageInput = voltageREF then
            pause 20
            VoltageDiff =  VoltageInput - VoltageREF      '=127-(182-127)
            DutyCycle = voltageREF - ( VoltageDiff - voltageREF )
            pause 20
    there must be better ways to accomplish this
    regards,
    K
    Default Re: Boost converter (sepic)
    I suppose what you did produces a small oscillation at the output.
    I had a similar implementation with that result.
    So I thought that PID routine made by Henrik could help me but had never managed to properly adjust the P-I-D settings:
    http://www.picbasic.co.uk/forum/showthread.php?t=5874
    Maybe you are in luck making it work for you.
  1. PIC18F26K80 A/D Converter
    By RayL113 in forum Code Examples
    Last Post: - 17th November 2012, 03:35
  2. MikroBasic to PBP Pro: Boost mode SMPS
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 25th November 2011, 02:27
  3. A/D converter sample
    By allan josephus in forum mel PIC BASIC
    Last Post: - 23rd February 2008, 19:44
  4. A/D converter
    By rocky79 in forum mel PIC BASIC Pro
    Last Post: - 1st October 2005, 06:40
  5. help D/A converter
    By matelda in forum mel PIC BASIC Pro
    Last Post: - 8th September 2004, 17:25
