DS18B20 Question
Results 1 to 7 of 7
Threaded View
  1. #4
    Apr 2011
    Welches, Oregon
    Default Re: DS18B20 Question
    When the temperature is changing from, say 72 degrees to 73 degrees or from 74 to 73 degrees I would expect it would take some time for the epoxy casing to heat/cool through to where the sensor is actually sensing. The datasheet indicates a conversion time of .1 - .75 seconds; are you allowing adequate time for the temperature change to propagate? Even as the sensor continues in the "correct" direction, there must be some lag between the actual temperature and the sensing element.
    If it is truly a hardware issue - and it requires a read/ write or some other electronic trigger to affect the suspect reading - then the problem should persist over several seconds or minutes. If you read say... once a minute... does the problem remain? What if you change the temperature rapidly - perhaps using "freeze spray" - to speed the temperature change of the body of the sensor, does this effect your results?
  1. ds18b20 code
    By leemarrow in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2016, 15:14
  2. Quick DS18B20 question
    By gti_uk in forum General
    Last Post: - 21st June 2009, 17:24
  3. Ds18b20
    By ahmed_salah in forum mel PIC BASIC Pro
    Last Post: - 14th June 2009, 15:21
  4. Ds18b20..
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 18th June 2008, 16:29
  5. using the DS18B20
    Last Post: - 22nd December 2006, 13:09
