PIC18F45K80 runs way to fast.
Results 1 to 4 of 4
    Dec 2014
    Default PIC18F45K80 runs way to fast.
    Hi.
    Im using the PIC18F45K80 for the very first time and use a 64MHz external clock source.
    To test the new hardware, and to see that it's alive, I just blinks en LED.
    The example blinks the LED way to fast, I just can se a flicker, but if I increse the pause to 5000, then it blinks 36 times in one minute.
    Anyone got an idea why this happens?
    while 1
        high portd.7
        low portd.7
    wend
    Here is my complete code:
    ' PIC18F45K80 Configuration Bit Settings
    ' Basic source line config statements
        CONFIG RETEN = OFF
        CONFIG INTOSCSEL = HIGH
        CONFIG SOSCSEL = HIGH
        CONFIG XINST = OFF
        CONFIG FOSC = EC3
        CONFIG PLLCFG = OFF
        CONFIG FCMEN = OFF
        CONFIG IESO = OFF
        CONFIG PWRTEN = ON
        CONFIG BOREN = OFF
        CONFIG BORV = 3
        CONFIG BORPWR = ZPBORMV
        CONFIG WDTEN = OFF
        CONFIG WDTPS = 1048576
        CONFIG CANMX = PORTB
        CONFIG MSSPMSK = MSK7
        CONFIG MCLRE = ON
        CONFIG STVREN = OFF
        CONFIG BBSIZ = BB2K
        CONFIG CP0 = OFF
        CONFIG CP1 = OFF
        CONFIG CP2 = OFF
        CONFIG CP3 = OFF
        CONFIG CPB = OFF
        CONFIG CPD = OFF
        CONFIG WRT0 = OFF
        CONFIG WRT1 = OFF
        CONFIG WRT2 = OFF
        CONFIG WRT3 = OFF
        CONFIG WRTC = OFF
        CONFIG WRTB = OFF
        CONFIG WRTD = OFF
        CONFIG EBTR0 = OFF
        CONFIG EBTR1 = OFF
        CONFIG EBTR2 = OFF
        CONFIG EBTR3 = OFF
        CONFIG EBTRB = OFF
    '************************* DEFINES ******************************
    define osc 64
    define adc_bits 12    ' Set number of bits in result
    define adc_clock 3     ' Set clock source (3=rc)
    define adc_sampleus 50    ' Set sampling time in uS
    'lcdout $FE,$80 rad 1, $FE,$C0 rad 2
    define lcd_dreg portc
    define lcd_dbit 0
    define lcd_rsreg portc
    define lcd_rsbit 4
    define lcd_ereg portc
    define lcd_ebit 5
    define lcd_bits 4
    define lcd_lines 2
    define lcd_commandus 3000
    define lcd_dataus 100
    '************************ REGISTERS *****************************
    ancon0 = 100000
    ancon1 = 000000
    adcon2.7 = 1
    '*********************** PORT CONFIG ****************************
    trisa = 100000                                   'porta direction 0=OUTPUT 1=INPUT
    porta = 000000                                   'porta preset
    trisb = 010111                                   'portb direction 0=OUTPUT 1=INPUT
    portb = 000000                                   'portb preset
    trisc = 000000                                   'portc direction 0=OUTPUT 1=INPUT
    portc = 000000                                   'portc preset
    trisd = 111111                                   'portd direction 0=OUTPUT 1=INPUT
    portd = 110000                                   'portd preset
    trise = 001111                                   'porte direction 0=OUTPUT 1=INPUT
    porte = 000000                                   'porte preset
    '*******************    MAIN PROGRAM     ************************
    while 1
        high portd.7
        low portd.7
    wend
    Default Re: PIC18F45K80 runs way to fast.
    I haven't looked at your CONFIGs and I've never run a PIC with a direct clock signal but the first thing that pops is
    define osc 64
    defines are case sensitive, osc and OSC are not the same.
    It absolutely MUST be define OSC 64.
    Dec 2014
    Thank you very much, now it works.
    Great, and remember that it applies to the other defines you've got in there as well.
  1. Replies: 15
    Last Post: - 27th January 2012, 17:10
  2. Mibam at 20mhz runs slower than at 4 mhz
    By Homerclese in forum mel PIC BASIC Pro
    Last Post: - 31st October 2010, 19:41
  3. clock runs reverse and fast:(
    By HYETİK in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2009, 12:44
  4. hardware counting while software runs
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2006, 04:26
  5. Ds1302 Stops are runs slow
    By Kman in forum mel PIC BASIC Pro
    Last Post: - 13th June 2006, 03:10
