DT interrupt and 12f683
Results 1 to 3 of 3
    May 2008
    Italy
    Default DT interrupt and 12f683
    '|             Name    : Light_12F683.BAS                                      |
    '|             Author  :                                                       |
    '|             Notice  : Copyright (c) 2010  All Rights Reserved               |
    '|             Date    : 18/12/2014                                            |
    '|             Version : 1.0                                                   |
    '|             Notes   : Pic 12F683 light controller                           |
    ' P12F683 (pin usage)
    ' pin # 1 = Vdd     (+ 5 Volts)
    ' pin # 2 = GPIO.5  (Digital output [Led])
    ' pin # 3 = GPIO.4  (N/U)
    ' pin # 4 = GPIO.3  (MCLR)
    ' pin # 5 = GPIO.2  (Digital output)
    ' pin # 6 = GPIO.1  (input chan B)
    ' pin # 7 = GPIO.0  (input chan A)
    ' pin # 8 = Vss     (ground)
    ;----[12F683 Hardware Configuration]--------------------------------------------
    #IF __PROCESSOR__ = "12F683"
      #DEFINE MCU_FOUND 1
    cfg = _INTOSCIO               ; INTOSCIO oscillator: I/O function
    cfg&= _WDT_OFF                ; WDT disabled
    cfg&= _PWRTE_OFF              ; PWRT disabled
    cfg&= _MCLRE_ON               ; MCLR pin function is MCLR
    cfg&= _CP_OFF                 ; Program memory code protection is disabled
    cfg&= _CPD_OFF                ; Data memory code protection is disabled
    cfg&= _BOD_ON                 ; BOR enabled
    cfg&= _IESO_ON                ; Internal External Switchover mode is enabled
    cfg&= _FCMEN_ON               ; Fail-Safe Clock Monitor is enabled
      __CONFIG cfg
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    include "ALLDIGITAL.pbp"
    DEFINE  SHOWDIGITAL 1
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts
    DEFINE OSC 8                        ' Oscillator frequency
        OSCCON = %01110111              ' oscillator setting internal 8 MHz
    '   ANSEL  = %00100000              ' set all digital
    '   CMCON0 = 7                      ' comparator off
    OPTION_REG = %11100000              ' weak pullup enabled
          GPIO = %00000000              ' set all pins to zero
        TRISIO = %00001011              ' configure direction  1=input 0=output
    Led             var GPIO.5          ' Alias for GPIO.5 pin # 2
    A_opto          var GPIO.0          ' Alias for GPIO.0 pin # 7
    B_Opto          var GPIO.1          ' Alias for GPIO.1 pin # 6
    Luce            var GPIO.2          ' Alias for GPIO.2 pin # 5
    wsave           VAR BYTE $20     SYSTEM
    wsave1          var byte $A0     SYSTEM
    A0              var byte
    B0              var byte
    C0              var byte
    F0              var byte
    Flag_Count      var byte
    Flag_In         var bit
    Flag_Out        var bit
    Flag_Count = 0
      Flag_Out = 0
       Flag_In = 0
            A0 = 0
            B0 = 0
            F0 = 0
    asm
    INT_LIST  macro             ; IntSource,        Label,  Type, ResetFlag?
            INT_Handler    GPC_INT,  _Opto_Read,    PBP,  yes
        INT_CREATE              ; Creates the interrupt processor
    @     INT_ENABLE GPC_INT
    goto Main
    '---------------------------------- Ini ISR ------------------------------------
    Opto_Read:
    A0 = GPIO & %00000011
    If A0 = 1 Then Flag_In = 1
    If A0 = 3 and Flag_In = 1 Then Flag_Count = Flag_Count + 1
    If A0 = 2 Then Flag_Out = 1
    If A0 = 3 and Flag_Out = 1 Then Flag_Count = Flag_Count - 1
    @  INT_RETURN
    If Flag_In = 1 and Flag_Count > 0 Then
    Luce = 1
    Flag_In = 0
    If Flag_Count > 100 then Flag_Count = 0
    If Flag_Out = 1 and Flag_Count = 0 Then
    Luce = 0
    Flag_Out = 0
    Pause 1
    F0 = F0 + 1
    If F0 > 200 then
    Led = !Led
    F0 = 0
    goto Main                           ' goes back to main loop
    end                                 ' end program
    I am not able to trigger the interrupt, can Somebody enlight me on what is wrong in the above code?
    Thank you
    Al.
    Default Re: DT interrupt and 12f683
    Try setting IOC = %00000011 to enable IOC interrupt on GPIO.0 and GPIO.1
    May 2008
    Italy
    Thank you Henrik , that was the trouble now the interrupt works as it shoud!
    Cheers
    Al.
  1. 12F683, TMR1 and ON INTERRUPT revisited
    By AvionicsMaster1 in forum PBP3
    Last Post: - 17th September 2013, 20:07
  2. 12f683 ADC help
    Last Post: - 26th November 2009, 22:37
  3. 12f683 help!!!! L@@K!!!
    By thm ov3rkill in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2008, 23:46
  4. 12F683 Startup
    By GregK in forum mel PIC BASIC Pro
    Last Post: - 19th March 2005, 01:25
  5. Replies: 0
    Last Post: - 27th August 2004, 08:20
