My first foray into PWM
Results 1 to 14 of 14
    Default My first foray into PWM
    Before I get too deep in this, can I blink an LED ON for 500uS, OFF for 500uS using standard PWM module?
    Or am I trying to use a Ferrari as a baby stroller?
    I know I can use DT_INT but I know how to do that and want to avoid using cycles. The PWM hardware is there doing nothing and I was hoping I could use it as a heartbeat during my tests.
    I've printed pages 186-189 of the 18F44K22 datasheet and it doesn't seem overwhelming at first glance. The only part I can't determine by reading that is if I can use it as slow as I want. I know this is meant to drive motors so it's entirely possible that it can't physically go this slow.
    EDIT: I'm running at 64MHz so I can guarantee persistence of vision while blinking at least 50 LEDs, manage a keypad and handle USART comms (at the very least). But I'm getting a feeling by looking at that PWM PERIOD formula at 14-1 that I could only do this if I slow to a crawl.
    Default Re: My first foray into PWM
    if you are using the hpwm command the max freq is 32767hz the min @64mhz ck is 3905 hz on a pic18
    max period 256uS min 30.5uS
    so you could at 50% duty get 128uS on 128uS off
    Yes, I definitely want the hardware PWM. But it's not the 50% duty that I was concerned with, it was the 1 second period.
    I see now the relation between clock speed and the PWM output. So there's no way I can get it slow enough to use it as a heartbeat (1 sec period) in the background if we limitted with a 4MHz lower range.
    I was hoping to use it as a debugging tool; to show that a PIC is indeed working without taking any clock cycles (disturbing cycle sensitive logic). And I wanted to try out HPWM, I'm nowhere near ready to get back on my CNC project; have to complete my residential alarm system first (and I'd like to get that interfacing with android, text messenging and web page - lots of learning).
    Apr 2011
    Welches, Oregon
    You might, if you have one laying around, use a clock divider chip... or a counter... Here's a link that explains my thinking better than I can.
    You might be able to achieve something using compare mode and the external clock pin for timer1. if you have enough spare pins and if you were really clever
    use the hpwm output to drive tmr1ck then you could change the flash rate on the fly
    Euh, I think I'll just get back to finishing my Charlie-plexing work for now. LOL
    Thanks though, I will have to jump into PWM one day, hopefully next summer.
    Hi Robert,
    In your first post you say LED ON for 500uS, OFF for 500uS but then you say you want a period of 1s - that's a difference of $03E8 times.
    I know you didn't want to do it with an normal interrupts but I'm going to suggest a simple timer interrupt anyway.... At such low frequencies (even though you're probably not going to get 500ms interrupt period in "on go") the interrupt processing will have very little impact on the overall performance.
    Aug 2008
    Portugal
    Hi Robert;
    An HeartBeat Led should be do it with a timer interrupt like Henrik sujested....
    If you cannot achieve tht time that you want, you do for instance, a 100ms interrupt and with a counter you can achieve the time that you want counting in 100ms spaces.
    You can count 5 x 100ms and then toogle the led.
    Thanks and Regards;
    Gadelhas
    Hi Robert,
    (without considering oscillator speed and PWM range limitations)
    Then there's something about PWM that I didn't understand. HIGH/LOW using PAUSE for 500uS is not the same as a 1000uS period with 50% duty cycle?
    Name:  PAUSE vs PWM.PNG
    Ooop, uS, not Us.
    Aug 2008
    Portugal
    Attachment 7531
    Ooop, uS, not Us.
    Yes, from that point of view, it is the same thing! (without considering oscillator speed and PWM range limitations)
    Thanks and Regards;
    Gadelhas
    Yes of course, 500us ON and 500us OFF is 50% dutycyle. But the period is 500us+500us = 1000us = 1ms = 0.001s - NOT 1s which you later wrote.
    In your first post you indicated you wanted a PWM period of 1000us (a frequency of 1000Hz). In your second post you said you wanted a period of 1s (a frequency of 1Hz). It doesn't add up - that's all I was trying to say.
    Ooops, my bad. Didn't explain myself properly.
    how to flash a pulse led @ 1 hz on a pic18 @64mhz with no code overhead and no interrupts
    for demon
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 29/11/2014                                        *
    '*  Notes   :   pic18f45k20                                                *
      CONFIG  FOSC = INTIO67
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRT = OFF
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 18
      CONFIG  WDTEN = ON
      CONFIG  WDTPS = 512
      CONFIG  CCP2MX = PORTC
      CONFIG  PBADEN = OFF
      CONFIG  LPT1OSC = OFF
      CONFIG  HFOFST = ON
      CONFIG  MCLRE = ON
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
      define OSC 64
       osccon=$70   '4 mhz
         trisc=%11111001
       trisd.1=0   ' another led
         T2CON = $4; // tmr2 prescale 0 and on
         PR2 = 255; // pwm period   ?
         CCP1CON = $c; // pwm mode
         CCPR1L = 127; // pw
         t1con=$43
         CCP2CON = 2
         t3con=3
         OSCTUNE.6=1
       ; ccp1 out connects to t1ck in and pulse led connected to ccp2 out
       ; on     pic18f45k20  ccp1 out = portc.2
       ;                     ccp2 out = portc.1
       ;                     ti ck in = portc.0
      latd.1= !latd.1       ;flash another led
    Neat, first I have to get my Charlie-plex going again. I broke it. LOL
  1. Replies: 1
    Last Post: - 4th March 2013, 22:57
  2. PWM to 0-5V
    By tallen in forum mel PIC BASIC Pro
    Last Post: - 30th April 2010, 09:03
  3. help with pwm
    By babatundeawe in forum Schematics
    Last Post: - 30th October 2008, 13:35
  4. Pwm
    By xobx in forum mel PIC BASIC Pro
    Last Post: - 11th February 2008, 07:33
  5. Pwm
    By JARI NETWORKS in forum mel PIC BASIC
    Last Post: - 1st September 2006, 07:03
