PBP command execution time
Results 1 to 17 of 17
Threaded View
  1. #4
    Default Re: PBP command execution time
    that why your own asm routines are often used , if you know every thing is in the same mem bank then ALL that bank ckecking (chk:rp) can be eliminated ,but what you have there is a lst file I would expect any decent compiler to optimise most if not all that unnecessary code out , the assembled file should look cleaner than that, but need to disassemble the hex file to see it
  1. Code speed and execution time
    By aajgss in forum mel PIC BASIC Pro
    Last Post: - 12th May 2011, 03:44
  2. Code execution time?
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 24th February 2009, 16:07
  3. Execution time in programme
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 16th November 2007, 22:29
  4. Command execution time
    By barkerben in forum General
    Last Post: - 7th December 2004, 20:29
  5. instruction execution time
    By tjg in forum Code Examples
    Last Post: - 21st April 2004, 18:15
