Charlie-plexing
Results 1 to 40 of 61
Thread: Charlie-plexing
    Jun 2016
    Default Re: Charlie-plexing
    Hi AvionicsMaster1
    The schematic is not really a schematic just a drawing to sort out the CharliePlex. There are 100 Ohm resistors on each pin.
    The spaces in the lookup didn't seem to make any difference to the running of the program but I will try it without them.
    Almost all of the code is from Richard and even with very slight errors i am finding it very instructive.
    thankyou for your observations
    regards
    Jim
    So Richard when I see 12 in the t,p column I am really looking at TRIS or PORT 1100 and 7 will be 0111 ?
    Jim
    yes the tris and port columns are binary 0b1100=0xC = 12 or pbp parlance %1100=$c=12
    this is where i was heading for the led cube , current irq rate is 1000 Hz to drive 64 leds that needs to 5 times faster
    this codes flashes all the odd leds for 1 sec and then all the evens then repeats
    '*  Name    : charlieplex.pbp                                        *
    '*  Author  : richard                                   *
    '*  Notice  :                                *
    '*  Date    :                                          *
    '*  Version :    16f1825     @3.3 volts                               *
    '*  Notes   :       *
                 __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_ON  &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
    DEFINE OSC 32
     include "dt_ints-14.bas"
     Include "REENTERPBP.bas"
    asm
    INT_LIST macro
          INT_HANDLER TMR1_INT, _TOCK, PBP ,YES
           INT_CREATE
    @timer1 =TMR1L
    leds var word
    tmp var byte
    x var byte
    timer1         VAR WORD EXT
    timer1=15543
    T1CON=$31
    @ INT_ENABLE  TMR1_INT
    OSCCON=$70
    ANSELA=0
    ANSELC=0
    mainloop:
    leds=1365
    leds=2730
    goto mainloop
    TOCK:
    T1CON.0=0
    timer1=timer1+64536
    T1CON.0=1
    if leds.0[x] then
        lookup x,[12,12,9,9,3,3,5,5,6,6,10,10],tmp
        TRISC =(TRISC&$f0)|tmp
        lookup x,[ 2, 1,4,2,8,4,8,2,8,1 ,4, 1],tmp
        latC =(latC&$f0)|tmp
    x=x+1
    if x=12 then x=0
    @ INT_RETURN
