Charlie-plexing
Results 1 to 40 of 61
Thread: Charlie-plexing
    Default Re: Charlie-plexing
    I used the wiring above for pins D.1, D.2 and D.3 on a 16F877 and it didn't work as expected.
    I get 3 LEDs blinking faintly instead of a single one. It seems as if the current loops over to the unused pin and comes back.
    I'll have to check out your thread. I must be missing something.
    ' Blink 6 LEDs connected to Port D.1, D.2 and D.3 in charlie-plex manner
    '   PIC             16F877      ext osc 20MHz
    '   PBP             v2.60c
    '   MPASM           v5.49
    '   MCS+            v2.1.0.7
    '   U2 programmer   v4.32
    asm
     __config _HS_OSC & _WDT_OFF & _PWRTE_OFF & _BODEN_ON & _LVP_OFF & _CPD_OFF & _WRT_OFF & _DEBUG_OFF & _CP_OFF
    endasm
    DEFINE OSC 20
    ADCON1 = 7                  ' Set Ports to digital
    TRISA = %00000000           ' Set all Ports to output
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00000000
    PORTA = %00000000           ' Set ports OFF
    PORTB = %00000000
    PORTC = %00000000
    PORTD = %00000000
    PORTE = %00000000
    mainloop:
        TRISD = %11111001       ' Enable pins D.1 and 2
        PORTD = %00000100       ' Turn ON pin D.2 --> D.1
        PORTD = %00000010       ' Turn ON pin D.1 --> D.2
    ;    TRISD = %11110101       ' Enable pins D.1 and 3
    ;    PORTD = %00001000       ' Turn ON pin D.3 --> D.1
    ;    pause 500
    ;    PORTD = %00000010       ' Turn ON pin D.1 --> D.3
    ;    pause 500
    ;    TRISD = %11110011       ' Enable pins D.2 and 3
    ;    PORTD = %00000100       ' Turn ON pin D.2 --> D.3
    ;    pause 500
    ;    PORTD = %00001000       ' Turn ON pin D.3 --> D.2
    ;    pause 500
        TRISD = %11111111       ' All pins disabled
        goto mainloop
    Jun 2016
    Hi AvionicsMaster1
    No big deal, someone on here reckons that mistakes are not mistakes but learning opportunities and I think he's right having had plenty of learning opportunities myself.
    Still getting them.
    Using your idea to copy and paste |OR Demon, thanks.
    Thanyou to Richard for keeping us right and for introducing me to the lookup command which has led me onto writing my code in decimal and hex.
    Having great fun with them, well this is a hobby and hobbies are supposed to be fun.
    The following code is for a set of traffic lights on the roads as part of a 1/76 scale model railway.
    '*  Name    : Four Way Traffic Lights                           *
    '*  Author  : Jim Hagan                                         *
    '*  Date    : 10/07/2016                                        *
    '*  Notes   : For 16F84A                                        *
        __CONFIG _XT_OSC & _CP_OFF
      'Defines
       DEFINE OSC 4          'Tell PBP3 expected system clock frequency
      'Aliases
       LEDS1 var PORTB        'Assign name LEDS1 to PORTB
       LEDS2 VAR PORTA        'Assign name LEDS2 to PORTA
       'Variables
       i var byte
       'Initialize
       TRISB = $0            'Set PORTB to Output
       TRISA = $0
       'Program Code
    START
       gosub REDGREEN
       gosub REDAMBER
       gosub GREENRED
       gosub AMBERRED
       goto START
    REDGREEN
       LEDS1 = $61            'LEDS 0, 5 and 6 on PORTB On
       LEDS2 = $08            'LED 3 on PORTA On
       pause 3000             'Puts lights on for 3 seconds
       for i = 1 to 10
       LEDS1 = $0
       LEDS2 = $0
       next i
    REDAMBER
       LEDS1 = $D3             'LEDS 0, 1, 4, 6 and 7 on PORTB On
       LEDS2 = $04             'LED 2 on PORTA On
       pause 2000              'Puts lights on for 2 seconds
       for i = 1 to 10
       LEDS1 = $0
       LEDS2 = $0
       next i
    GREENRED
       LEDS1 = $C              'LEDS 2 and 3 on PORTB On
       LEDS2 = $03             'LEDS 0 and 1 on PORTA On
       pause 3000
       for i = 1 to 10
       LEDS1 = $0
       LEDS2 = $0
       next i
    AMBERRED
       LEDS1 = $9A              'LEDS 1, 3, 4 and 7 on PORTB On
       LEDS2 = $06              'LEDS 1 and 2 on PORTA On
       pause 2000
       for i = 1 to 10
       LEDS1 = $0
       LEDS2 = $0
       next i
    Jim
