Charlie-plexing
Results 1 to 40 of 61
Thread: Charlie-plexing
    Default Re: Charlie-plexing
    As I sit down to think how to manage this, one MAJOR drawback:
    You had better not forget any LEDs on your project 'cause adding one later is going to be "troublesome".
    You can always add it at the bottom of your truth table, but I'm the obsessive compulsive type that likes symetry; LEDs are handled in the logic as they are placed on the circuit board. Remnants of hating spaghetti code on mainframes (COBOL + GOTO = NIGHTMARES).
    Some neat stuff I forgot that I found several years ago on Charlie-plexing.
    clear
    define osc4
    cmcon0=7
    ansel=0
    adcon0 = 0
    @ device mclr_off
    @ device wdt_off
    @ device bod_off
    @ device cpd_off
    @ device protect_off
    led var byte
    ledstates var byte
    trisstate var byte
    delay var word
    noghost var byte
    gpnoghost var byte
    noghost= %111111
    delay= 1500
    starthere:
    gpio.3 = 0
    if gpio.3 = 1 then
    goto starthere
    for led = 1 to 6
      select case led
        case 0 : ledstates =%001 : trisstate =%100
        case 1 : ledstates =%010 : trisstate =%100
        case 2 : ledstates =%001 : trisstate =%010
        case 3 : ledstates =%100 : trisstate =%010
        case 4 : ledstates =%100 : trisstate =%010
        case 5 : ledstates =%010 : trisstate =%001
        case 6 : ledstates =%100 : trisstate =%001
      end select
      trisio = noghost
      gpio = ( gpio & %111000) | ledstates
      trisio = (trisio & %111000) | trisstate
      pause delay
    next led
    for led = 1 to 5
      select case led
        case 1 : ledstates =%000001: trisstate =%101110
        case 2 : ledstates =%011000: trisstate =%101110
        case 3 : ledstates =%000010: trisstate =%101101
        case 4 : ledstates =%010000: trisstate =%101101
        case 5 : ledstates =%000010: trisstate =%011101
      end select
      trisio = noghost
      pause delay
    next led
    trisio=noghost
    gpio=gpnoghost
    goto starthere
    Name:  Multiplex pins schematic.GIF
    Editted to add some colour, original was black on light gray background.
    I wish I could give a link and credit, but I can't find anything on google for this now (been looking for over an hour).
    Last edited by Demon; - 14th December 2014 at 21:42. Reason: Added code instead of PDF
    Sep 2010
    Las Vegas, NV
    Did this a while ago. Don't know if it will help. http://www.picbasic.co.uk/forum/showthread.php?t=14220
    If you use the above program you'll need to change you define osc line.
    Good luck.
    I used the wiring above for pins D.1, D.2 and D.3 on a 16F877 and it didn't work as expected.
    I get 3 LEDs blinking faintly instead of a single one. It seems as if the current loops over to the unused pin and comes back.
    I'll have to check out your thread. I must be missing something.
    ' Blink 6 LEDs connected to Port D.1, D.2 and D.3 in charlie-plex manner
    '   PIC             16F877      ext osc 20MHz
    '   PBP             v2.60c
    '   MPASM           v5.49
    '   MCS+            v2.1.0.7
    '   U2 programmer   v4.32
    asm
     __config _HS_OSC & _WDT_OFF & _PWRTE_OFF & _BODEN_ON & _LVP_OFF & _CPD_OFF & _WRT_OFF & _DEBUG_OFF & _CP_OFF
    endasm
    DEFINE OSC 20
    ADCON1 = 7                  ' Set Ports to digital
    TRISA = %00000000           ' Set all Ports to output
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00000000
    PORTA = %00000000           ' Set ports OFF
    PORTB = %00000000
    PORTC = %00000000
    PORTD = %00000000
    PORTE = %00000000
    mainloop:
        TRISD = %11111001       ' Enable pins D.1 and 2
        PORTD = %00000100       ' Turn ON pin D.2 --> D.1
        PORTD = %00000010       ' Turn ON pin D.1 --> D.2
    ;    TRISD = %11110101       ' Enable pins D.1 and 3
    ;    PORTD = %00001000       ' Turn ON pin D.3 --> D.1
    ;    pause 500
    ;    PORTD = %00000010       ' Turn ON pin D.1 --> D.3
    ;    pause 500
    ;    TRISD = %11110011       ' Enable pins D.2 and 3
    ;    PORTD = %00000100       ' Turn ON pin D.2 --> D.3
    ;    pause 500
    ;    PORTD = %00001000       ' Turn ON pin D.3 --> D.2
    ;    pause 500
        TRISD = %11111111       ' All pins disabled
        goto mainloop
    Jun 2016
    Hi AvionicsMaster1
    No big deal, someone on here reckons that mistakes are not mistakes but learning opportunities and I think he's right having had plenty of learning opportunities myself.
    Still getting them.
    Using your idea to copy and paste |OR Demon, thanks.
    Thanyou to Richard for keeping us right and for introducing me to the lookup command which has led me onto writing my code in decimal and hex.
    Having great fun with them, well this is a hobby and hobbies are supposed to be fun.
    The following code is for a set of traffic lights on the roads as part of a 1/76 scale model railway.
    '*  Name    : Four Way Traffic Lights                           *
    '*  Author  : Jim Hagan                                         *
    '*  Date    : 10/07/2016                                        *
    '*  Notes   : For 16F84A                                        *
        __CONFIG _XT_OSC & _CP_OFF
      'Defines
       DEFINE OSC 4          'Tell PBP3 expected system clock frequency
      'Aliases
       LEDS1 var PORTB        'Assign name LEDS1 to PORTB
       LEDS2 VAR PORTA        'Assign name LEDS2 to PORTA
       'Variables
       i var byte
       'Initialize
       TRISB = $0            'Set PORTB to Output
       TRISA = $0
       'Program Code
    START
       gosub REDGREEN
       gosub REDAMBER
       gosub GREENRED
       gosub AMBERRED
       goto START
    REDGREEN
       LEDS1 = $61            'LEDS 0, 5 and 6 on PORTB On
       LEDS2 = $08            'LED 3 on PORTA On
       pause 3000             'Puts lights on for 3 seconds
       for i = 1 to 10
       LEDS1 = $0
       LEDS2 = $0
       next i
    REDAMBER
       LEDS1 = $D3             'LEDS 0, 1, 4, 6 and 7 on PORTB On
       LEDS2 = $04             'LED 2 on PORTA On
       pause 2000              'Puts lights on for 2 seconds
       for i = 1 to 10
       LEDS1 = $0
       LEDS2 = $0
       next i
    GREENRED
       LEDS1 = $C              'LEDS 2 and 3 on PORTB On
       LEDS2 = $03             'LEDS 0 and 1 on PORTA On
       pause 3000
       for i = 1 to 10
       LEDS1 = $0
       LEDS2 = $0
       next i
    AMBERRED
       LEDS1 = $9A              'LEDS 1, 3, 4 and 7 on PORTB On
       LEDS2 = $06              'LEDS 1 and 2 on PORTA On
       pause 2000
       for i = 1 to 10
       LEDS1 = $0
       LEDS2 = $0
       next i
    Jim
    Quote Originally Posted by AvionicsMaster1 View Post
    Good luck.
    LMAO!
    I posted YOUR program above! I googled and searched this forum to try and find where I got it from but never found it.
    I'll have to look this over again, I must miss something obvious. You have GPIO, I only see PORT and TRIS registers as relevant on a 16F877.
    Partly fixed.
    I was using 3 red, green and yellow LEDs; they have wildly different current draw/voltage drops. I switched to all greens and the ghosting effect is practically gone.
    I saw your comments about ghosting and noticed you output PORT before TRIS, didn't help me; tried both ways.
    EDIT:
    asm
    endasm
    DEFINE OSC 20
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00000000
    PORTB = %00000000
    PORTC = %00000000
    PORTD = %00000000
    PORTE = %00000000
    mainloop:
        goto mainloop
    Jun 2016
    Hi
    Looks like I made a wrong post??
    Don't know what?
    OK
    On topic, the March 2018 Nuts and Volts Magazine has an article on "Charlieplexing an analog style LED clock", by Robert Gill. It drives 182 LEDs with 14 I/Os.
    Isn't that impressive?
Members who have read this thread : 7
