PCB Coating remover
Results 1 to 5 of 5
    Default Re: PCB Coating remover
    It looks like RTV silicone caulk. Good luck..... You should be able to peel most of it by hand. I would use an EXACTO Knife also...
    EN82fn
    Or heat sink compound. Is it rubbery or past like? If it turns out to be RTV be sure to not allow lithium batteries in that device, seems RTV & lithium combine to form a severe corrosive situation, FAA made folks replace ELTs many moons ago.
    EDIT: On second look, I think Dave is correct. RTV. Now, the question is do you want to trim the edges or UNPOT the PCB? Stoddard solvent will turn RTV to jelly, do not know if it will harm anything else.
  1. Replies: 0
    Last Post: - 4th June 2014, 04:06
  2. Re: Pcb cleaning
    By Steve_88 in forum Off Topic
    Last Post: - 10th March 2008, 08:05
  3. Weather prove coating
    By bartman in forum Off Topic
    Last Post: - 11th December 2004, 15:19
