Using "END" Fries PICS?
Results 1 to 14 of 14
    Dec 2014
    Default Using "END" Fries PICS?
    I discovered that placing an "end" statement in the middle of a program rendered my 16f819 useless. Somehow it prevented the chip from ever programming again. I used up 7 chips while tracing this down.
    Dec 2014
    Dec 2014
    Default Re: Using "END" Fries PICS?
    I'm using an old MELabs USB Programmer and melabs Programmer V 4.51 beta software. I have NOT write protected the 16F819 chip. I have it configured such:
    osc = INTRC
    WDT = enabled
    Power up timer = Enabled
    MCLR pin funct = input pin
    Brownout reset = Enabled
    Low voltage programming = Disabled
    CCP multiplex = RB2
    Flash prog mem write enable = All
    code = Not Protected
    Data EEPROM = Not Protected
    Here is my code:
     INCLUDE "modedefs.bas"
    define osc 4
    osccon= %01100000
    DEFINE	ADC_BITS	8	'this sets number of a/d bits, using 10 gives much higher resolution
    DEFINE	ADC_CLOCK	2	'choose clock source for a/d, 2 gives a stable reading
    DEFINE	ADC_SAMPLEUS	50	'sample wait time 50 microseconds
    'LCD declarations-------------
    CR	CON	13	'carriage return
    LF	CON	10	'cursor down one line keeps horiz position
    crsrH	CON	1	'home cursor
    bell	CON	7	'beep
    clrlcd	CON	12	'clear the lcd
    poscmd	CON	16	'position cursor
    N9600	CON	$4054	'value for 9600 baud setting
     PORTA = 0
     PAUSE 1
     PORTB = 0
     PAUSE 1
     trisa = %11000001
     trisb = %00000000
     ADCON1 = %00001110
     commpin		VAR	porta.4	'serial pin to LCD
     Button1 var porta.1
      MuxOutput var byte
      SwSelect var byte
      SwSelect = 8
    GoSub kls
     SerOut2 commpin,n9600,[CLRLCD,bell]
    mainloop:
    end 'NEVER use "end"!!!!  it destroys the chip!
    portb = swselect
    adcin 0,muxoutput
    gosub lcdtext
    gosub SelectSwitch
    gosub button1NOTpressed
    goto mainloop
    SelectSwitch:
    Swselect=swselect + 1
        if swselect = 16 then
            swselect = 8
    lcdtext:
    SerOut2 commpin,n9600,[crsrh,"T",dec (portb-7),"=",dec muxoutput,"   REQ=",bin portb,"     "]
    SerOut2 commpin,n9600,["                    ",lf]
    button1NOTpressed:
    adcin 0,muxoutput
    gosub lcdtext
    	IF button1 = 1 Then
            GoTo button1NOTpressed 		'hold here until button released
    	EndIF
    	gosub button1pressed
    button1pressed:
    	IF button1 = 0 Then
            GoTo button1pressed 		'hold here until button released
    	EndIF
     'Clears LCD screen --------------
    KLS:
    SerOut2 commpin,n9600,[clrlcd]
    beep:
    	SerOut2 commpin,n9600,[bell]			'tech 8 beep
    After programming the chip, it never programs again. All I get when trying to reprogram is the error message "Target Device does not match selected device".
    I had that problem with the pic18f45k80. It had something to do with using the MCLR pin as an input.
    Melabs was able to help me by updating the programmer software. I don't believe the END statement
    is your problem. Read this article it may help.
    http://www.gooligum.com.au/tutorials...rog_issues.pdf
    Dec 2014
    Quote Originally Posted by mark_s View Post
    The problem went away when I removed the "end" statement. It looks to me that having MCLR as an input pin and then declaring it as an output and then writing "end" in the mainloop causes the MCLR pin to be pulled low when it is powered up, thereby ignoring MCLR when trying to program it. That is a curious state of affairs. I wonder if there is a way around this?
    Look at the datasheet and confirm the MCLR pin can be used as an output. MCLR on the 18F44K22 can only be an input; making it an output can have unexpected results.
    mainloop:
    this code is rather strange : you send clear and bell , Then place your chip in sleepmode ???
    I hope you have left the Watchdog ON ...
    to me, you should use STOP command here ...
    now, why include " modedefs" and after place this line :
    Dec 2014
    Quote Originally Posted by Acetronics2 View Post
    mainloop:
    The program was under development and being debugged when this problem cropped up. The "end" was part of the search for the cause of the chips becoming non-programmable.
    last news ...
    using MPLAB + Picstart for programming cause an ICD CRASH !!!
    buuuut ....
    Everything goes fine with MPLAB + ICD2 ...
    just CR and BELL generate compiling errors ( WHY ??? ), changing them for CR0 and BELL0 clears any reported problems.
    answer is in the modedef.bas file :
     ' Debug / Serial Constants
    Symbol CLS = 0
    Symbol HOME = 1
    Symbol BELL = 7
    Symbol BKSP = 8
    Symbol TAB = 9
    Symbol CR = 13
    Memory is well programmed and erased ...
    so your chips are not dead ... probably it is a programmer issue in the end.
    a very intersting post ...
    http://www.microchip.com/forums/m532131.aspx
    http://www.microchip.com/forums/m303686.aspx
    I had somewhere in my brain the "Vpp first" option was to use with some chips ...
    also think you have some errors to clear in your program ... ( double definitions ...)
    Ok questions: What programmer are you using? Which programmer software are you using? Can you post your "config" statement? Have you made sure you are not setting code protect on?
    EDIT: So, I just tried to duplicate your problem in one of my programs . . . I put end in a subroutine where it should not be and as expected it stopped the program there (that's what it does) but I am able to restart the pic, AND I was able to reprogram it with no problem. I think you should post your code for forensic examination.
    I have had many times where the programmer just wanted to give me a hard time and code protect the chip and not want to reprogram the chip using a PICKitII, and this I found works:
    Step 1. make sure to turn off code protect.
    try to erase if fails select the Wrong chip, I repeat, select the wrong chip
    this will clear the program area.
    Step 2. Select the correct chip and then click WRITE this will program the chip with hex 3FFF at every location, effectivly erasing the PIC
    Step 3.ClickAuto Import Hex + Write Device select the hex you wish to program and it will program properly (hopefully).
    I often place END statement @ the bottom of EACH subroutine when programming some device that must not reach " la la land " ... or accidentally fall into the next sub ...
    NEVER got any problem , especially about reprogramming ...
    by the way ...
    the END statement place a never ending SLEEP LOOP @ the locations of the program you type it, like that
    in asm :
    SLEEP
    GOTO $-1 ' or goto the label corresponding to the sleep command,
    Hi there,
    I agree with Mark_S.
    I learned the hard way with 16f88 MCUs and the MCLR issue.
    The problem is not the fact of using the MCLR pin as input, but as a combination of MCLR as input and internal OSC option.
    Everytime i design some circuit that will use the internal osccilator i know i will lose the MCLR pin.
    About the MCUs mentioned, i was never able to recover them.
    Rui
  1. Replies: 0
    Last Post: - 14th November 2013, 04:32
  2. Replies: 3
    Last Post: - 15th October 2012, 09:06
  3. Replies: 7
    Last Post: - 21st July 2011, 11:34
  4. Using "END" in a subroutine?
    Last Post: - 13th February 2010, 17:32
