Hserin with Array
Results 1 to 5 of 5
    Default Re: Hserin with Array
    Byte banging. :-)
    I'd test using only one byte instead of array. I'd Hserin wait for start character, process byte (could be moving into 256 byte array, increment bytes found counter), Hserin byte, goto process byte until receive end character, process array, start over.
    Start-end can be anything you won't usually receive #$%&*+<>~|√π§Δ£¢€¥^°±{}/\!¡©®™℅[]¿?().
    Hserin one byte multiple times might be more efficient than always receiving a large array, or it might not.
    Feb 2012
    South Carolina, USA
    Robert,
    I started off in that direction but ended up confused in the loop trying to pull out parts of the array (GET /?ESP1=R1&ESP2=R2&ESPx=%25 HTTP/1.1) and separate the parts for ESP1 and ESP2 vars. I will definitely revisit it before moving to far forward.
    John
  1. Hserin Array Question
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 9th May 2012, 03:39
  2. Copying Array to Array
    By vamtbrider in forum mel PIC BASIC Pro
    Last Post: - 24th April 2010, 02:12
  3. Bit/Byte array for Hserin/Hserout
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2006, 00:07
  4. Custom array of ports using array?
    By blainecf in forum mel PIC BASIC Pro
    Last Post: - 18th June 2006, 02:43
  5. Word array behaving like byte array.... wierd
    By forgie in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2005, 16:43
