In the C version there's a d_mode variable which you're checking
your right of course
that's the way I eliminated the redundant loop in the c version
looks like I skipped that step for pbp
code size now 336 and functional equivalence restored
thanks for noticing that
*  Name    : UNTITLED.BAS                                      *
'*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
'*  Date    : 29/11/2014                                        *
'*          :   pic12f1822                                                *
cfg1 = _FOSC_INTOSC
cfg1&= _WDTE_ON
cfg1&= _PWRTE_OFF
cfg1&= _MCLRE_ON
cfg1&= _CP_OFF
cfg1&= _CPD_OFF
cfg1&= _BOREN_ON
cfg1&= _CLKOUTEN_OFF
cfg1&= _IESO_ON
cfg1&= _FCMEN_ON
  __CONFIG _CONFIG1, cfg1
cfg2 = _WRT_OFF
cfg2&= _PLLEN_OFF
cfg2&= _STVREN_ON
cfg2&= _BORV_19
cfg2&= _LVP_OFF
  __CONFIG _CONFIG2, cfg2
DEFINE OSC 8
include "dt_ints-14.bas"
include "REENTERPBP.bas"
asm
INT_LIST macro
      INT_HANDLER  INT_INT, _TL, PBP,yes
      INT_CREATE
      INT_ENABLE INT_INT
    osccon=$70    '8 mhz
    anselA=0        'dig i/o
    ANSELC=0
    TRISC= %11110000
    TRISA= %011111
    APFCON0.7=0
     OPTION_REG.6=0
  a  var  byte
  b  var  byte
  c  var  byte
  d  var  byte
  pin_mode var bit
  d_mode var bit
  x var byte
  all_off var byte
  pins_on var byte
  led var lata.5
  a=1        ;portC.0
  b=2         ;portC.1
  c=4         ;portC.2
  d=8         ;portC.3
  pin_mode=0
  d_mode=1
  all_off=~(a+b+c+d)
   led=0
  latC =   latC & all_off
 action:
  if d_mode then
  pins_on=a+b
  pins_on=c+d
  for x = 1 to 5
  latC =   latC | pins_on
  pause 200
  pause 200
  next x
  if !d_mode  then  gosub shuffle
     d_mode= !d_mode
  goto action
   shuffle :
   pin_mode = not pin_mode
  if pin_mode then
  swap a,d
  swap b,c
  swap b ,d
  swap c ,d
TL:
 led=!led
@ INT_RETURN
