when 128k is not enough
Results 1 to 40 of 82
    Default Re: when 128k is not enough
    they are now . I had a few copy paste errors where the second delay fell off the c version and the pbp still had a unnecessary loop in it as well as the led initialising to 0 line misplaced into the loop .I just saw the leds flashing and assumed all was equal . the outcome is largely unaffected anyway . I was really just quantifying the interrupt latency for my own edification , I still don't think the code size comparison is valid a fairer test probably needs a few serout2's and a lcdout and a onwire or two to be meaningful .
    the mikro c is now 193 bytes and the pbp 315 other than
    In the C version there's a d_mode variable which you're checking
    your right of course
    that's the way I eliminated the redundant loop in the c version
    looks like I skipped that step for pbp
    code size now 336 and functional equivalence restored
    thanks for noticing that
    *  Name    : UNTITLED.BAS                                      *
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 29/11/2014                                        *
    '*          :   pic12f1822                                                *
    cfg1 = _FOSC_INTOSC
    cfg1&= _WDTE_ON
    cfg1&= _PWRTE_OFF
    cfg1&= _MCLRE_ON
    cfg1&= _CP_OFF
    cfg1&= _CPD_OFF
    cfg1&= _BOREN_ON
    cfg1&= _CLKOUTEN_OFF
    cfg1&= _IESO_ON
    cfg1&= _FCMEN_ON
      __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF
    cfg2&= _PLLEN_OFF
    cfg2&= _STVREN_ON
    cfg2&= _BORV_19
    cfg2&= _LVP_OFF
      __CONFIG _CONFIG2, cfg2
    DEFINE OSC 8
    include "dt_ints-14.bas"
    include "REENTERPBP.bas"
    asm
    INT_LIST macro
          INT_HANDLER  INT_INT, _TL, PBP,yes
          INT_CREATE
          INT_ENABLE INT_INT
        osccon=$70    '8 mhz
        anselA=0        'dig i/o
        ANSELC=0
        TRISC= %11110000
        TRISA= %011111
        APFCON0.7=0
         OPTION_REG.6=0
      a  var  byte
      b  var  byte
      c  var  byte
      d  var  byte
      pin_mode var bit
      d_mode var bit
      x var byte
      all_off var byte
      pins_on var byte
      led var lata.5
      a=1        ;portC.0
      b=2         ;portC.1
      c=4         ;portC.2
      d=8         ;portC.3
      pin_mode=0
      d_mode=1
      all_off=~(a+b+c+d)
       led=0
      latC =   latC & all_off
     action:
      if d_mode then
      pins_on=a+b
      pins_on=c+d
      for x = 1 to 5
      latC =   latC | pins_on
      pause 200
      pause 200
      next x
      if !d_mode  then  gosub shuffle
         d_mode= !d_mode
      goto action
       shuffle :
       pin_mode = not pin_mode
      if pin_mode then
      swap a,d
      swap b,c
      swap b ,d
      swap c ,d
    TL:
     led=!led
    @ INT_RETURN
  1. Saving space - close to 128k
    Last Post: - 26th October 2014, 07:16
  2. writecode at upper half of 128K parts?
    By Tomasm in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2004, 20:02
