Every compiler implementation is different. You may find some C compilers are better than others in using the available resources (read registers) to do a certain job. Others may be quite simple and un-optimized (think small-c). C or Basic makes no difference other than the implementation. It is the coder who needs to decide which to use and how.
Coming to implementation, some compilers keep tabs on which registers are used to pass values between the caller/callee, locally used in the routine and push/pop only those. Some other compilers may choose to simply save an entire register bank - no matter what the time cost.
I do not code arduino, but, I think they hide a lot of implementation from the user within their libraries. That makes it like PBP an excellent rapid app development (RAD) tool and so they have plenty of users. On the other hand, hiding the details means accepting the compiler authors view of the world. You either use it or roll your own/better code. PBP has a similar concept of hiding code behind its library of commands and also allowing you to roll your own.
As for interrupts, PBP does have simple polled interrupt handling that may be quite insufficient if you compare it with other compilers for the same platform. However, that is what it gives you; it also lets you mix assember with basic which is a major plus if you know how to asm.
In my personal opinion, string handling, re-entrant functions, variable scoping, native interrupt handling are the hurdles if you use PBP for large projects. The lack of string handling functions is definitely a handicap for many, but using some asm done by DT(RIP), you surely can overcome the limitations by writing your own functions.
