Wow Richard, that post of yours was almost as hard to read as a C program :-)
commands like hserin hserout block until they complete whereas in arduino c the equivalents serial.print() and serial.read() are both interrupt driven out of the box
Got it. Of course having it interrupt driven by default has drawbacks of its own. Is it high/low priority? Does it in turn block other interrupts? How much overhead does it add in term of interrupt processing etc etc. I suspect there are commands available that does not use interrupts so I do get your point.
but the biggest difference is the architecture of coding style in c most have a main loop that executes as fast as possible calling functions on the way to see if they need servicing each function of course uses time from the main loop but only when needed (think of a token ring) . in basic most programmers make the code like a string doing functions sequentially
Yes, but IMO that boils down to bad practice more that one anything else. As you say, there is no wrong way it's just different. Personally I tend to use statemachines quite a bit, either that or the main loop is pretty much a bunch of If ThisFlag then GOSUB xxx, if ThatFlag GOSUB yyy which pretty much turns it into the C style you describe (I think).
when it comes to interrupts c wins hands down sure its got to dump a heap of stuff into the stack and pop it off again but its much less than dt-ints doing a pbp style irq quite noticeably in fact , although often it doesn't matter
It must come from the fact that C uses local variable so the compiler always knows what variables are in scope and therefor what to variables it needs to save (?) (but how does it know when the interrupt fires at compile time....). On the other hand, doesn't that make for unpredicatble latency, ie one interrupt it needs to save 5 variables, next interrupt it needs to save 10? I'm asking, not arguing by the way ;-)
you have to appreciate commands like serial.available() give you the number of byte in the serial buffer. serial.find("ok") returns true if serial buffer has ok in it . imitating those functions in pbp is not easy (don't forget the buffer is filling in the background as you search and if it overflows all can be lost )
Definitely so! Handling strings IS limited in PBP, there's no doubt about that.
floats are interesting in xc8 /hightec c for pic one float command adds nearly 8k to you pgm so workarounds are very worthwhile . / mikroc pretty much the same sourceboost c has a weird float library that takes multiple steps to achieve and adds up to about the 8k of the others anyway . yet on an arduino you'd hardly notice
That it adds 8k doesn't surprise me one bit. What does surprise me is the fact that it's hardly noticable with Arduino C. Is it possible that it's hiding the size of library stuff? Arduino is based on GCC right?
