Automotive sensor display system
Results 1 to 17 of 17
    Pinckney, Michigan
    Default Re: Automotive sensor display system
    I started a project some time ago with the following features.
    1. Battery voltage monitoring
    2. 4 EGT thermocouple channels
    3. 4 CHT thermocouple channels
    4. Electric water pump current monitoring
    5. Water temp
    6. Oil temp
    7. Charge Air temp
    8. O2 sensor via serial port
    9. Manifold pressure
    10. Barometric sensor
    11. Tachometers
    12. Log data to a compact flash card
    13. Graphic LCD output via serial port (Text and bar graphs)
    Software is 80-90% complete but written in Proton syntax. Would be a relatively simple port to PICBasic.
    Circuit board is complete.
    Project was designed for an aircraft application, but the project went away.
    PM me. We'll talk.
    I have an agriculture Android based electric motor controller that I use Bluetooth to communicate with the PIC chip(s)
    I use B4A (basic for android) It is great.
    Example screen shots
    http://www.grahamelectricplanter.com/gc/
    Feb 2008
    Michigan, USA
    That looks quite nice. thanks for letting me know about it.
    bo
  1. Automotive sensor
    By davidhay in forum Off Topic
    Last Post: - 22nd January 2012, 14:28
  2. Persistence of Vision on Automotive wheel
    By Wax-um in forum mel PIC BASIC Pro
    Last Post: - 24th January 2009, 16:06
  3. DS1307 automotive application
    By DynamoBen in forum Schematics
    Last Post: - 31st August 2006, 01:33
  4. Automotive Use
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 20th August 2006, 11:04
  5. Automotive quality rotary encoder
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 8th October 2004, 16:46
