Multi component tester
Results 1 to 18 of 18
    Default Multi component tester
    Here's something I picked off ebay;
    This guy can test most 2 / 3 lead components (transistors,triacs,thyristors,diodes, LEDs, resistors, caps...) AND identify their leads as well.
    Name:  2014-09-30 14.24.24.jpg
    It helped me weed out all the bad mosfets I had in my junkbox, and identify the generic type of devices on which the markings had got erased.
    Thought it would be useful to folks on the forum.
    Anand
    Default Re: Multi component tester
    Moved to FAQ and stickied cause this is a gem.
    Thanks, Robert.
    I was so impressed with this gadget I did some research, and found that this is based on an original design out in the public domain. The basic version has *very* simple hardware, Unfortunately, based on the *other* family of micros.
    For anybody wanting to roll their own: http://translate.google.com/translat...Fpage_id%3D148
    Anand
    Hi Anand,
    Well, you just sold one to me, I also just ordered an ESR tester a couple of days ago, had never really seen one before, seems it is for all practical purposes an A/C ohm meter, as it tests capacitors at 100kc. I will review it when the kit comes.
    BTW, this tester you showed us is MUCH cheaper than the esr tester.
    EDIT: 12/10/2014
    This is the esr meter , I bought the kit:
    http://www.mainelectronics.com/esrkit.htm
    I assembled it last night . . . Works Great !
    Glad!
    Further probing reveals that the original design was by a guy called Marcus. Later, his design was improved upon by Karl, and he's keeping on adding features to it (including ESR, I think). The Chinese stuff on Ebay is pretty much based on that.
    I put together a basic, minimalistic version of the original for a pal (minus the auto-switch off circuitry and the LCD, the data displayed on the LCD is also given out on the UART, can be monitored on the PC).
    Quote Originally Posted by Acetronics2 View Post
    This seller is cheaper, no bidding: http://www.ebay.com/itm/271611840945...78.m2749.l2649
    Halas ...
    Unfortunately, access to this particular item has been blocked due to legal restrictions in some countries
    no joy ...
    no joy ...
    Not to worry. If you'd like to build one (a very basic version with text LCD), I can send you the firmware files. I programmed the ATMEGA8 using just a parallel cable and 4 resistors. In fact, you dont even need the LCD, you can connect it to a PC over a serial port.
    Anand
    Hi, Anand
    Mine is on the way home ( from the link I gave ) ... but it ( no joy ) is not available for me from the Ebay page Archangel gave.
  1. What component to use to control inrush current?
    By Megahertz in forum General
    Last Post: - 10th March 2013, 18:22
  2. Motor Controller component suggestions
    By Tobias in forum General
    Last Post: - 5th March 2010, 07:16
  3. Can not recoganize this component?
    By Megahertz in forum Schematics
    Last Post: - 20th December 2009, 16:07
  4. Electronic Component Suppliers
    By paulwoody in forum Off Topic
    Last Post: - 24th October 2007, 17:13
  5. Component Device Support ?
    By sirnoname in forum USB
    Last Post: - 27th June 2007, 14:08
