Error using DT's Inst Interrupts and PIC BASIC PRO Long
Results 1 to 7 of 7
    Default Re: Error using DT's Inst Interrupts and PIC BASIC PRO Long
    Thanks Robert -
    I have PBPL enabled (the box is checked)
    Ken
    Is it working?
    Div32 is not used with longs as all division is 32 bit using longs
    DT's Interrupts have nothing to do with this problem.
    It seems that whenever a div32 is used with longs, I get the error.
    To simplify things, I am using Bruce's temperature conversion routine, reading a DS18B20, and it uses a DIV32 statement.
    This all works fine, except when I want to use LONGS for another variable elsewhere in the program, then I get the error.
    If I comment out the DIV32, there is not a compile error, but of course the temperature is screwed up.
    I can display the LONG variable just fine in either case.
    Yes, I do have the LONG box selected.
    I guess I just will not attempt to use a LONG variable with a program that uses DIV32.
    Ken
    Found the problem - - RTFM - -
    Bottom of page 40 of the PBP manual
    Ken
  1. DT's Instant Interrupts
    By andywpg in forum mel PIC BASIC Pro
    Last Post: - 1st June 2014, 18:01
  2. Question about DT's Interrupts
    By tazntex in forum General
    Last Post: - 15th June 2010, 01:36
  3. DT inst. interrupt & Timer0 with pic 16F88
    By aratti in forum mel PIC BASIC Pro
    Last Post: - 17th December 2009, 21:23
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  5. Replies: 5
    Last Post: - 17th January 2006, 19:26
