Nokia LCD - datasheet
Results 1 to 8 of 8
    Dec 2007
    Finland
    Default Re: Nokia LCD - datasheet
    Use Google search and there you have it.
    Lumia 520 schematics
    Display is using MIPI DSI interface, so PIC's are not suitable for driving the display alone.
    In addition, you will need a SW user manual for that... Better to look another, easier, display module
    Oct 2009
    Thanks for the advice
    LMAO : Frustrating and Relieving at the same time, someone tells you to do , exactly what you did to no avail, but words the search a bit differently and viola there is what you were looking for. So it does not only happen to me.
    Thanks to you both !
    Oct 2009
    Yup, you're not the only one.
    I tried things like "Nokia lumina 520 LCD spec", "Lumia 520 PCB schematic" etc, - No luck at all.
    What would we do without forums such as this eh !
    Thanks guys
    Could be worse.
    I googled Buick Rendezvous 2002 problems, did not find a single relative hit, bought the truck.
    Aaaaaaand then the problems began. Googled the same thing and it went on for pages...
    GAAAAAAAAAA!
    Edit: replacing the spark plugs Monday, have to undo front engine mounts to tilt it for access.
    Replaced the universal joints, $25 each on older cars, these are press fit into the driveshaft. Need a machinist to replace them, then he has to balance driveshaft.
    Replaced thermostat, usually under 30 minutes total, but no, have to undo a ton of crap and it's at the rear. Back bolt is just unreal.
    The list just goes on.
    Could have been worse, you could have bought a ford with 5.8 L. It costs $800 to buy the tool to remove a broken spark plug and about an hour each to do it. you have to glue a stud into the broken insulator, pull that, tap the broken shell and use the puller tool to remove that. Check YouTube there is video.
    Brother-in-law has one, terrible designers.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Replies: 9
    Last Post: - 18th March 2013, 23:52
  3. Large LCD ID and datasheet
    By skimask in forum Off Topic
    Last Post: - 17th May 2008, 16:44
  4. nokia 3210 data cable (datasheet)
    By joseph Degorio in forum GSM
    Last Post: - 4th December 2006, 01:05
  5. Nokia 3310 LCD
    By barkerben in forum General
    Last Post: - 10th December 2005, 20:08
