PBP 2.6, MCC 3.0.0.5 & WIN 7 x64 - Need help. please, with @ config
Results 1 to 7 of 7
    Dec 2008
    Ploiesti, ROMANIA
    Default PBP 2.6, MCC 3.0.0.5 & WIN 7 x64 - Need help. please, with @ config
    Hi everybody !
    I upgrade my PC to WIN7 (X64) because of Assassin Creeds (for my little son ) and now I am unable to compile my programs ...
    I tried to find one solution through forum and www, but without success ...
    Can anyone guide me in the right direction? Thanks in advance !
    Default Re: PBP 2.6, MCC 3.0.0.5 & WIN 7 x64 - Need help. please, with @ config
    I bet you "reinstalled" PBP from the setup disks, didn't you? So if you did, All of those xxx.inc files you modified are now back the way M E Labs made them.
    Your configs are wrong for that chip
    @ __config _HS_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    you used mclr should be mclre, you used BOD should be BOREN . . .PWRTE not PWRT read the link I posted
    Dec 2008
    Ploiesti, ROMANIA
    Thank you !
    ...but I still missing something ?!
    Dec 2008
    Ploiesti, ROMANIA
    Solved !
    For my purpose only :
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _BODEN_OFF & _LVP_OFF & _CP_ON
    Thanks for advice !
    Great! While you were solving it I was writing this which I will post to help someone in the future:
    Different chips have different config "words" for the same thing.
    each PIC has a file in the C:\Program Files(x86)\microchip\MPASM suite directory. This chips
    file name is P16F628A.inc . Every register and every config this PIC
    has is defined there. When you compile, this file is included
    and the configs you put into your code MUST MATCH the configs
    in this file. SPELLING COUNTS ! MCLR is NOT the same as MCLRE. . . .
    You show the 16F628A.inc folder open, in there see the config statement.
    You must declare that statement a comment by inserting a semicolon just
    ahead of it ; like so ;__config _xt_OSC . . .  save it and close it.
    Now when PBP includes it the config is only a comment and you will no longer have the "Overwriting error".
    Dec 2008
    Ploiesti, ROMANIA
    Thanks again for info !
    My mistake : tried to modify the .inc file from PBP\INC folder ...not from MICROCHIP\MPASM folder.
  1. advice on 240 x64 displays
    Last Post: - 4th June 2013, 17:39
  2. config words with pic18f's & PICkit2
    By archendekta in forum mel PIC BASIC Pro
    Last Post: - 17th October 2010, 10:59
  3. 16F886 Config & Defines
    Last Post: - 10th June 2010, 17:27
  4. ICD & PBP && how to get it to work
    Last Post: - 24th March 2010, 01:56
  5. Tracing & Stepping: PBP & MPLAB
    By chicowoodhill in forum mel PIC BASIC Pro
    Last Post: - 7th September 2008, 01:23
