RFID Voter please help!
Results 1 to 9 of 9
    Dec 2014
    Default RFID Voter please help!
    This is quite urgent,
    i have a project that i will be defending on Friday (5th December ), I am new to programming and have really done some work coding in PICBasic.
    I have to code a PIC18F4550 micro controller for ELECTRONIC VOTING SYSTEM using RFID Identification system, but i need the code to accept four (4) digit verification code before allowing voting to continue but i don't know how to go about it...
    The code can only ID the tags but I cannot take it further than than due to my limited knowledge of PICBasic programming.Ii need the code to request for a four-digit pin that will be assigned to each tag number in order to verify after system ID tags. please I need urgent help as the defense date is so close. below is the code so far.......
    '@ DEVICE PIC16F628A
    INCLUDE "modedefs.bas"
    CMCON = 7
    DEFINE OSC 4 'Set oscillator in MHz
    TRISA=%11100
    TRISB=%00000010
    DEFINE LCD_DREG PORTB 'define port to LCD
    DEFINE LCD_DBIT 4 'RB4 RB5 RB6 RB7 to D4 D5 D6 D7 display
    DEFINE LCD_RSREG PORTA 'RS on porta
    DEFINE LCD_RSBIT 0 'RS on porta.0
    DEFINE LCD_EREG PORTA 'Enable on porta
    DEFINE LCD_EBIT 1 'Numero Enable porta.1
    DEFINE LCD_BITS 4 '
    DEFINE LCD_LINES 2 'lines 2
    PAUSE 200 ' Stop 200ms
    LCDOUT $FE,1 ' power lcd
    'Lcdout $FE,1,4
    lcdout $FE, 1," Copyright 2014"
    lcdout $FE, $C0,"  ELECTRONIC    "
    lcdout $FE, $90," VOTING SYSTEM   "
    lcdout $FE, $D0," TECHNOLOGIES   "
    pause 5000
    lcdout $FE,1
    ' -----[ Variables ]-------------------------------------------------------
    buf VAR byte [10]' RFID bytes buffer
    tagNum VAR Byte ' from EEPROM table
    idx VAR Byte ' tag byte index
    char VAR Byte ' character from table
    MEK VAR BYTE
    IFE VAR BYTE
    ' -----[ EEPROM Data ]-----------------------------------------------------
    Tag1 DATA "0002864330"
    Tag2 DATA "450052F2EB"
    ' -----[ Initialization ]--------------------------------------------------
    'high portb.1 ' turn off RFID reader portb.1 is the reciever port
    LOW portb.2 ' lock the door! Low portb.3 ' Turn off LED
    ' -----[ Program Code ]----------------------------------------------------
    MEK=0
    IFE=0
    lcdout $FE,1," PLEASE USE YOUR"
    lcdout $FE, $C0,"  TAG FOR ID  "
    high portb.3
    low portb.1 ' activate the reader
    SERIN2 portb.1,84,[WAIT($02),STR buf\10]
    high portb.1 ' deactivate reader
    Check_List:
    FOR tagNum = 1 to 2 ' scan through known tags
    FOR idx = 0 TO 9 ' scan bytes in tag
    READ (((tagNum-1)*10) + idx), char ' get tag data from table
    IF (char <> buf(idx)) THEN Tag_Found'Bad_Char ' compare tag to table
    NEXT
    'GOTO Tag_Found ' all bytes match!
    Bad_Char: ' try next tag
    NEXT
    Bad_Tag:
    tagNum = 0
    FREQOUT porta.3, 1000 */ $100, 115 */ $100 ' groan
    lcdout $FE, 1," invalid TAG"
    lcdout $FE, $C0," try again"
    lcdout $FE,1
    GOTO Main
    Tag_Found:
    'IF tagNum = 1 then displayName1
    'IF tagNum = 2 then displayName2
    lcdout $FE, 1,"WELCOME YOU CAN  "
    LCDout $FE, $C0,"  NOW VOTE     "
    pause 4000 'Pause ,5 sec then clear display
    lcdout $FE, 1,"PRESS A FOR PDP  "
    LCDout $FE, $C0,"PRESS B FOR ACN  "
    lcdout $FE, $90,"PRESS C FOR APGA "
    lcdout $FE, $D0,"PRESS D FOR APP  "
    GOSUB VOTE
    GOTO Main
    VOTE:
    IF PORTA.2=0 THEN CAND1
    PAUSE 10
    IF PORTA.3=0 THEN CAND2
    PAUSE 10
    GOTO VOTE
    CAND1:
    MEK=MEK+1
    lcdout $FE, 1,"PDP =",#MEK
    LCDout $FE, $C0," ACCESS GRANTED"
    pause 4000
    GOTO  Main
    CAND2:
    IFE=IFE+1
    lcdout $FE, 1,"ACN =",#IFE
    LCDout $FE, $C0," ACCESS GRANDED"
    pause 4000
    GOTO  Main
    'displayName2:
    'lcdout $FE, 1,"  UGOCHUKWU  "
    'LCDout $FE, $C0," ACCESS GRANDED"
    'pause 3000 'Pause ,5 sec then clear display
    'goto open_door
    'displayName1:
    'lcdout $FE, 1,"   EMEKA   "
    'lcdout $FE, $C0, "ACCESS GRANDED"
    'goto open_door
    'open_door:
    'HIGH portb.2 ' remove latch
    'pause 500
    'LOW portb.2 ' restore latch
    'Low portb.3 ' LED OFF GOTO Main
    goto Main
    please house , I need this, and will appreciate your your assistance
    thank you!
    Default Re: RFID Voter please help!
    Looks like you used code from another PIC but didn't change the settings. You only have CMCOM, are you sure about this?
    I'm not sure about how you use port A for the LCD. Does it work right?
    Dec 2014
    yes, i was testing code on PIC16F628A mostly for hardware "handshaking" , worked on it, so i think it'll work on the PIC18F4550. i just want the code modified to "ask" for a (4-digit ) pin number for every tag that will be registered. before voting continues
    Dec 2014
    ok, can anyone help on how to input value (for comparison) in EEPROM table
    how many rfid tags do you expect to process ,you realise of couse that that chip has only 256 bytes of eprom (ie 25 tags)
    where does the pin value come from and how is linked to the rfid tag?
    and surely once a tag has "voted" it needs to be removed from the active list ?????
    for 25 tags its hardly worth the effort except maybe as an educational exercise
    LABOR RATES
    Normal………………………………$12.50
    If you wait…………………………..$15.00 per hour
    If you watch………………………..$20.00 per hour
    If you help………………………….$30.00 per hour
    If you worked on it first………..$50.00 per hour
    Deposit $1 x 2^(32-days to deadline)
    . . . and surely once a tag has "voted" it needs to be removed from the active list ?????
    WHAT ? ? ? No Vote for me, and vote often?
    Dec 2014
    Just for educational purpose, it's a mini school project.......the pin value is randomly selected for each tag and must not be changeable.
    Quote Originally Posted by philosofa View Post
    DATA to store, READ to retrieve.
    the special tag costs extra
  1. RFID Issues.... HELP !!!!!
    By andybarrett1 in forum mel PIC BASIC Pro
    Last Post: - 11th September 2014, 10:00
  2. RFID example.
    By StevenLim in forum General
    Last Post: - 8th February 2011, 09:08
  3. Garbage in from RFID
    By lilimike in forum Serial
    Last Post: - 6th December 2009, 14:55
  4. Rfid?
    By toalan in forum Off Topic
    Last Post: - 11th February 2005, 23:37
  5. RFid reader
    By paul farrugia in forum mel PIC BASIC Pro
    Last Post: - 14th January 2005, 20:27
