Shuffling variables
Results 1 to 18 of 18
    Jan 2010
    Default Shuffling variables
    OK, spent the better part of the night sorting through threads, but haven't found exactly what I was looking for. The process seems simple, but the pic finds it very complex. Here's what I'm trying to do. I have a large amount of code that pulses 4 outputs. Two outputs vs. the other two outputs. What I would like to do is be able to change the pairings of these outputs (i.e. 1 and 2 vs. 3 and 4, to 1 and 4 vs. 2 and 3 to 1 and 3 vs. 2 and 4).
    I've tried using variables, variable on variables, if..then statements, select case and even include files. The pics don't like this. I even looked at Darrel's virtualport code, but unless I'm mistaken, it's only for bits to ports. How can I change the ports, or their assignments around?
    Tony
    Default Re: Shuffling variables
    Could you draw a picture of what you're try to achieve and approx speed of pulses?
    George
    Last edited by towlerg; - 29th November 2014 at 10:48. Reason: old , stupid and can't spell
    Apr 2011
    Welches, Oregon
    Yes, I too think more description, and perhaps, some code would help. For one thing there are many ways to do the same thing and by knowing which path you've taken it might be less obtrusive to follow along rather than reinvent the wheel, so to speak. Also, are you designing - and might have room or to add external circuitry (say a logic gate or mux chip) - or must this be exclusively software?
    Jan 2010
    It must be strictly code. The following code is just a small, simple example of pulsing four outputs.
      a  var  portb.0
      b  var  portb.1
      c  var  portb.2
      d  var  portb.3
    action:
      for x = 1 to 5
        a = 1
        b = 1
        c = 0
        d = 0
      pause 200
        a = 0
        b = 0
        c = 0
        d = 0
      pause 200
      next x
      for x = 1 to 5
        a = 0
        b = 0
        c = 1
        d = 1
      pause 200
        a = 0
        b = 0
        c = 0
        d = 0
      pause 200
      next x
      goto action
    What I want to do with the code is be able to change the assignment of the ports when an external input is received, therefore to be able to change the assignment as follows:
      a  var  portb.3
      b  var  portb.2
      c  var  portb.1
      d  var  portb.0
    or
      a  var  portb.0
      b  var  portb.3
      c  var  portb.2
      d  var  portb.1
    or
      a  var  portb.0
      b  var  portb.2
      c  var  portb.1
      d  var  portb.3
    This is the only part I'm struggling with. I can do the rest of the code, but to change the assignment, I am having great difficulty.
    As I said, I tried using if..then statements, select case, the above variables won't work once they've been set. I even tried using other variable to substitute for the port aliases. My setup didn't like it. To me it looks like it should work, but the pic might not see it that way.
    Don't judge where the returns are and missing code. That was done just so you know that they didn't flow into each other. The way it works is that when action is run, it runs through its code continuously until a button is pressed. Once pressed, it jumps to an on..gosub command where it advances the pairing change option by one. When the pairs have been reassigned, it goes back to action and runs the code with the new pairing assignment.
      a  var  portb.0
      b  var  portb.1
      c  var  portb.2
      d  var  portb.3
      e  var  word
      f  var  word
      g  var  word
      h  var  word
    pair1:
    '  1 and 2 vs. 3 and 4
      e = a
      f = b
      g = c
      h = d
      return                         ' return to pairing change
    pair2:
    '  1 and 4 vs. 2 and 3
      e = a
      f = d
      g = b
      h = c
    action:
    ' alternating flash
      for x = 1 to 5
        e = 1
        f = 1
        g = 0
        h = 0
        pause 200
        e = 0
        f = 0
        g = 0
        h = 0
        pause 200
      next x
      for x = 1 to 5
        e = 0
        f = 0
        g = 1
        h = 1
        pause 200
        e = 0
        f = 0
        g = 0
        h = 0
        pause 200
      next x
    Does any of this make any sense and am I at all on the right track or at least headed in the right direction or did I hit a dead end?
    I'm not sure that helped. All I got from that was at different times the mapping between the bit variables A,B,C and D and the physical bits 0 thro 3 of PortB varies according to some rule.
    Is that correct?
    George
    Miami, Florida USA
    Quote Originally Posted by ERMEGM View Post
    Well, you are having great difficulty because you cannot reassign ports like that in the program. Ports are only assigned to variables at the beginning of the program.
    Anonymous
    looks like a dead end to me . try this way
    code is for a 12f1822 so uses porta and porta.3 is input only . but you get the idea
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 29/11/2014                                        *
    '*          :   pic12f1822                                                *
    cfg1 = _FOSC_INTOSC
    cfg1&= _WDTE_ON
    cfg1&= _PWRTE_OFF
    cfg1&= _MCLRE_ON
    cfg1&= _CP_OFF
    cfg1&= _CPD_OFF
    cfg1&= _BOREN_ON
    cfg1&= _CLKOUTEN_OFF
    cfg1&= _IESO_ON
    cfg1&= _FCMEN_ON
      __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF
    cfg2&= _PLLEN_OFF
    cfg2&= _STVREN_ON
    cfg2&= _BORV_19
    cfg2&= _LVP_OFF
      __CONFIG _CONFIG2, cfg2
       osccon=$6a    '4 mhz
       anselA=0
       trisa=000
      a  var  byte
      b  var  byte
      c  var  byte
      d  var  byte
      pin_mode var byte
      x var byte
      a=0
      b=1
      c=2
      d=4
      pin_mode=0
     action:
      for x = 1 to 5
      lata.0[a] = 1
      lata.0[b] = 1
      lata.0[c]= 0
      lata.0[d]= 0
      pause 200
      lata.0[a] = 0
      lata.0[b] = 0
      lata.0[c]= 0
      lata.0[d]= 0
      pause 200
      next x
      for x = 1 to 5
      lata.0[a] = 0
      lata.0[b] = 0
      lata.0[c]= 1
      lata.0[d]= 1
      pause 200
      lata.0[a] = 0
      lata.0[b] = 0
      lata.0[c]= 0
      lata.0[d]= 0
      pause 200
      next x
      gosub shuffle
      goto action
       shuffle :
       pin_mode=pin_mode+1
      select case pin_mode
      case 1
       a=4  ;a  var  portb.3
       b=2  ;b  var  portb.2
       c=1   ;c  var  portb.1
       d=0    ;d  var  portb.0
      case 2
       a=0  ;a  var  portb.0
       b=4  ;b  var  portb.3
       c=2   ;c  var  portb.2
       d=1    ;d  var  portb.1
      case 3
       a=0  ;a  var  portb.0
       b=2  ;b  var  portb.2
       c=1   ;c  var  portb.1
       d=4    ;d  var  portb.3
      case 4
       a=0  ;a  var  portb.0
       b=1  ;b  var  portb.1
       c=2   ;c  var  portb.2
       d=4    ;d  var  portb.3
       pin_mode=0
      end select
    another approach
    '*          :   pic12f1822                                                *
    cfg1 = _FOSC_INTOSC
    cfg1&= _WDTE_ON
    cfg1&= _PWRTE_OFF
    cfg1&= _MCLRE_ON
    cfg1&= _CP_OFF
    cfg1&= _CPD_OFF
    cfg1&= _BOREN_ON
    cfg1&= _IESO_ON
    cfg1&= _FCMEN_ON
    cfg2 = _WRT_OFF
    cfg2&= _PLLEN_OFF
    cfg2&= _STVREN_ON
    cfg2&= _BORV_19
    cfg2&= _LVP_OFF
       osccon=$6a    '4 mhz
       anselA=0
       trisa=000
      a  var  byte
      b  var  byte
      c  var  byte
      d  var  byte
      pin_mode var byte
      x var byte
      all_off var byte
      pins_on var byte
      a=1        ;portb.0
      b=2         ;portb.1
      c=4         ;portb.2
      d=16        ;portb.4
      pin_mode=0
      all_off=!(a+b+c+d)
      lata =   lata & all_off
     action:
      pins_on=a+b
      for x = 1 to 5
      lata =   lata | pins_on
      pause 200
      pause 200
      next x
      pins_on=c+d
      for x = 1 to 5
      pause 200
      pause 200
      next x
      gosub shuffle
      goto action
       shuffle :
       pin_mode=pin_mode+1
      case 1
       a=16  ;a  var  portb.3
       b=4  ;b  var  portb.2
       c=2   ;c  var  portb.1
       d=1    ;d  var  portb.0
      case 2
       a=1  ;a  var  portb.0
       b=16  ;b  var  portb.3
       c=4   ;c  var  portb.2
       d=2    ;d  var  portb.1
      case 3
       a=1  ;a  var  portb.0
       b=2  ;b  var  portb.2
       c=2   ;c  var  portb.1
       d=16    ;d  var  portb.3
      case 4
       a=1  ;a  var  portb.0
       b=2 ;b  var  portb.1
       c=4   ;c  var  portb.2
       d=16    ;d  var  portb.3
       pin_mode=0
      end select
    Feb 2011
    It is possible to use variables to name ports then change variable values to change ports. copied from my program --
    http://www.harbornet.com/sunflower/PCB.pbp
    ' The PORTL and PORTH aliases are used for the PIN numbers (0-15)
    ' PORTL is 0-7 and PORTH is 8-15.
    ' Look in the .bas and .bal files for the chip you are using.
    ' If it's a 18F4620 then open c:\pbp\18F4620.bas
    ' PORTL VAR PORTB
    ' PORTH VAR PORTD
    ' TRISL VAR TRISB
    ' TRISH VAR TRISD
    ' PORTB AND PORTD can now be referenced by variables.
    ' http://www.picbasic.co.uk/forum/showthread.php?t=14493&
    The default, I believe, is PORTB AND PORTC. The above changes in .bas and .bal changed that to ports B and D. The link explains in more detail
    Feb 2011
    if azMotor then
    azMotor_A = m1_ina '14 PORTD.6 ' Digital I/O PORT D.0 - D.7 NUMBERED 8 - 15
    azMotor_B = m1_inb '13 PORTD.5
    azMotor_A = m1_inb ' Software will reverse wires if motor or sensor installed backwards. 0 to 7 = PORTB.0 to PORTB.7
    azMotor_B = m1_ina ' Configured in Install subroutine. Used in Set_Motors HBridge subroutine. 8 to 15 = PORTD.0 to PORTD.7
    low azmotor_a ' Brake azimuth motor
    low azmotor_b
    sunflower that's very interesting , but I suspect it may fail if attempted on latx registers which can still leave you exposed to rmw issues . has anybody tried it on latx ?
    I could be wrong but most pbp "functions" find the tris reg by using a fixed offset from the port reg
    Jan 2010
    Yes I know this. I was having difficulty because I was trying to think of a way to do it in a manner that the pic would understand. Our brains can easily process this and substitute that values, but with the pic, it's not that easy.
    '*          :   pic12f1822                                                *
    cfg1 = _FOSC_INTOSC
    cfg1&= _WDTE_ON
    cfg1&= _PWRTE_OFF
    cfg1&= _MCLRE_ON
    cfg1&= _CP_OFF
    cfg1&= _CPD_OFF
    cfg1&= _BOREN_ON
    cfg1&= _IESO_ON
    cfg1&= _FCMEN_ON
    cfg2 = _WRT_OFF
    cfg2&= _PLLEN_OFF
    cfg2&= _STVREN_ON
    cfg2&= _BORV_19
    cfg2&= _LVP_OFF
       osccon=$6a    '4 mhz
       anselA=0
       trisa=000
      a  var  byte
      b  var  byte
      c  var  byte
      d  var  byte
      pin_mode var byte
      x var byte
      a=0
      b=1
      c=2
      d=4
      pin_mode=0
     action:
      for x = 1 to 5
      lata.0[a] = 1
      lata.0[b] = 1
      lata.0[c]= 0
      lata.0[d]= 0
      pause 200
      lata.0[a] = 0
      lata.0[b] = 0
      lata.0[c]= 0
      lata.0[d]= 0
      pause 200
      next x
      for x = 1 to 5
      lata.0[a] = 0
      lata.0[b] = 0
      lata.0[c]= 1
      lata.0[d]= 1
      pause 200
      lata.0[a] = 0
      lata.0[b] = 0
      lata.0[c]= 0
      lata.0[d]= 0
      pause 200
      next x
      gosub shuffle
      goto action
       shuffle :
       pin_mode=pin_mode+1
      case 1
       a=4  ;a  var  portb.3
       b=2  ;b  var  portb.2
       c=1   ;c  var  portb.1
       d=0    ;d  var  portb.0
      case 2
       a=0  ;a  var  portb.0
       b=4  ;b  var  portb.3
       c=2   ;c  var  portb.2
       d=1    ;d  var  portb.1
      case 3
       a=0  ;a  var  portb.0
       b=2  ;b  var  portb.2
       c=1   ;c  var  portb.1
       d=4    ;d  var  portb.3
      case 4
       a=0  ;a  var  portb.0
       b=1  ;b  var  portb.1
       c=2   ;c  var  portb.2
       d=4    ;d  var  portb.3
       pin_mode=0
      end select
    That's exactly what I was envisioning in my head, but I couldn't get it out. Thank you Richard. I'll try to plug this into my code and see how it works.
    up until now I never found a use for "swap" this makes even smaller and more elegant code
    '*          :   pic12f1822                                                *
    cfg1 = _FOSC_INTOSC
    cfg1&= _WDTE_ON
    cfg1&= _PWRTE_OFF
    cfg1&= _MCLRE_ON
    cfg1&= _CP_OFF
    cfg1&= _CPD_OFF
    cfg1&= _BOREN_ON
    cfg1&= _IESO_ON
    cfg1&= _FCMEN_ON
    cfg2 = _WRT_OFF
    cfg2&= _PLLEN_OFF
    cfg2&= _STVREN_ON
    cfg2&= _BORV_19
    cfg2&= _LVP_OFF
       osccon=$6a    '4 mhz
       anselA=0
       trisa=000
      a  var  byte
      b  var  byte
      c  var  byte
      d  var  byte
      pin_mode var bit
      x var byte
      all_off var byte
      pins_on var byte
      a=1        ;portb.0
      b=2         ;portb.1
      c=4         ;portb.2
      d=16        ;portb.4
      pin_mode=0
      all_off=!(a+b+c+d)
     action:
      pins_on=a+b
      for x = 1 to 5
      pause 200
      pause 200
      next x
      pins_on=c+d
      for x = 1 to 5
      pause 200
      pause 200
      next x
      gosub shuffle
      goto action
       shuffle :
       pin_mode =!pin_mode
      if pin_mode then
      swap a,d
      swap b,c
      swap a ,c
      swap b ,d
    shuffle wrong this is better
       shuffle :
       pin_mode =!pin_mode
      if pin_mode then
      swap a,d
      swap b,c
      swap b ,d
      swap c ,d
    Last edited by richard; - 30th November 2014 at 12:26. Reason: pressed wrong button
    Apr 2011
    Welches, Oregon
    ...this is better...
    Better? I'd say it's AWESOME! I had thought to suggest (as your original answer) using array values or various mask patterns perhaps, but - to my humble skills - there is simply no improvement possible to "swap". Somewhere, in the back of my mind, I remember seeing it, but had forgotten... I'll remember now!
    Jan 2010
    That's awesome, however, I have one question. What is (=!)? Can you please translate to English what the line "pin_mode =!pin_mode" means. That's the only part I'm having a problem with right now. The good book references it at !=, but that is used when you have two expressions, not the same expression. The same expression will always be equal to itself.
    Tony
    ! is the logical not operator afaik , anyway that's the way I use it (its a C thing but works in pbp too)
    I think its the same as the "tilde" ~ but my laptop keyboard makes it hard to find. maybe someone can confirm this
    pin_mode = ! (pin_mode) is the way to read it , if pin_mode is 1 then ! pin_mode becomes 0 or if pin_mode is 0 then ! pin_mode becomes 1
    not to be confused with != which is not equal to
    ps
    just tried it . seems "~ ! not" are all the same thing (on bit and byte vars anyway) for what it worth
    Apr 2011
    Welches, Oregon
    In binary, where there are two states, "NOT" or any variation thereof (~ ! etc) reverses the bit value, so... NOT 1 = 0. It makes sense on a bit level... if it's NOT a zero, it must be a one, yes? Now, of course if it is not, not a one, then it was all along a zero. In comedy, the "double negative" can lead to all sorts of Don Knott's style of humor - in computer science... not so much.
  1. How about String Variables?
    By mytekcontrols in forum PBP Wish List
    Last Post: - 20th January 2015, 13:53
  2. Replies: 2
    Last Post: - 12th November 2014, 08:57
  3. IF - WHILE and variables
    Last Post: - 15th April 2009, 14:01
  4. Using Variables with Debug
    By krohtech in forum mel PIC BASIC Pro
    Last Post: - 17th December 2007, 03:47
  5. Help with using variables
    Last Post: - 19th June 2005, 17:03
