Error - Unable to find symbol name in string table
Results 1 to 6 of 6
    Quebec, Canada
    Default Re: Error - Unable to find symbol name in string table
    I saw it too, maybe its a part of a regular expression...
    I've opened a webticket on microchip.com, I have no expectation on this...
    for what its worth mine looks like this
    make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
    make[1]: Entering directory `C:/Users/rc/Documents/xc8/pbppwm.X'
    make -f nbproject/Makefile-default.mk dist/default/production/pbppwm.X.production.hex
    make[2]: Entering directory `C:/Users/rc/Documents/xc8/pbppwm.X'
    gnumkdir -p build/default/production
    "C:\PBP3\pbpx.exe" -ampasmx -k# -os -p18f45k20 pbppwm.pbp
    PICBASIC PRO(TM) Compiler 3.0.7.4, (c) 1998, 2013 microEngineering Labs, Inc.
    All Rights Reserved.
    gnumkdir -p dist/default/production
    cp pbppwm.HEX dist/default/production/pbppwm.X.production.hex
    cp pbppwm.COF dist/default/production/pbppwm.X.production.cof
    rm -f pbppwm.COF
    make[2]: Leaving directory `C:/Users/rc/Documents/xc8/pbppwm.X'
    make[1]: Leaving directory `C:/Users/rc/Documents/xc8/pbppwm.X'
    BUILD SUCCESSFUL (total time: 5s)
    Loading code from C:/Users/rc/Documents/xc8/pbppwm.X/dist/default/production/pbppwm.X.production.hex...
    Loading symbols from C:/Users/rc/Documents/xc8/pbppwm.X/dist/default/production/pbppwm.X.production.cof...
    Loading completed
    I find the pbp source file must !!! be in the source folder of the project or it all goes pear shaped
    overall I find mplabx not worth the effort for pbp files , its just my two cents worth
    Quebec, Canada
    Richard: what IDE are you using? I really don't like mplabx
    I bought MicroCode Studio Plus with plans to use the icd but my laptop has no serial ports and I have nothing but trouble getting usb/serial adapters to work reliably with the icd ,4 times out of 5 I get connection timeout and then even if I get it to connect the connection drops out after a while (tried about 4 different ones all had issues). so I gave up on source level debugging and just use MicroCode Studio for pbp now . I find it adequate.
    there is also FineLineIDE kicking around it seemed promising if one is interested in learning something new, I think I have enough on my plate for now
  1. Replies: 3
    Last Post: - 20th December 2009, 13:57
  2. Compile Error - How to find it???
    Last Post: - 4th January 2007, 00:19
  3. Message String Table using Readcode
    By mytekcontrols in forum Code Examples
    Last Post: - 11th July 2005, 00:17
  4. Fatal error (unable to open)
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 26th April 2005, 11:43
  5. Undefined Symbol error when using ASM interrupt
    By toalan in forum mel PIC BASIC Pro
    Last Post: - 11th January 2005, 22:41
