i need help
Results 1 to 4 of 4
Thread: i need help
    illas's Avatar
    illas Guest
    Arrow i need help
    i have some problem copy a save temp data to PORTC
    first:
    BANKSEL RCSTA
    movlw 0
    movwf RCSTA
    i will turn off serial port being use in PORTC.
    second:
    BSF STATUS,5
    clrf TRISC
    BCF STATUS,5
    clrf PORTC
    make the portc as output port.
    e.g: already bit set bit0,1,2 then wanna store into a temp file register
    temp inside value will be 0x7. which mean bit,0,1,2 will be in high stats
    movf PORTC,W
    movwf temp ; temp register
    then for some reason want copy back to portc
    movf temp,W
    movwf PORTC
    here the problem i faced, it gave me 0 value in PORTC.
    Help Help Help
    anyone know the problem here ? urgently
    thank you
    Assembler //////programmers DEVIL\\\\\\\
    if i read/understand correctly you read from a whole port wich is currently set as output on all pins and then, you want to send the same value to the same portc??? sounds bad to me....
    i'm probably wrong on all but i try to stay as far to the assembler as i can. A brief description of what you want to do and the whole code will be appreciated on PM. i have some spare time and can try to make it work.
    Since it's a PicBasic forum, i doubt that you'll find many answer from many user(exept 2-3) here. the best way i guess is to go to Microchip forum where all "assembler guru's" reside. or post a request on their tech support site... sometimes they answer fast.
    here's the link
    http://support.microchip.com/scripts...=webticketcust
    illas's Avatar
    illas Guest
    hi steve
    i was doing a project. for some reason i need to copy variable file register to the portc. but anyway i found the mistake i make. i really thank that you willing
    to help me.
    Illas, The problem is this, you are not writing any thing other than 00h to PortC after setting it to all outputs.
    BSF STATUS,5
    clrf TRISC <---------- sets direction register for ALL output
    BCF STATUS,5
    clrf PORTC <-------------- sets port latch register for 00h
    movf PORTC,W <-------- copy portc to w (portc = 0oh)
    movwf temp ; temp register <----- copy w to temp (w = 00h)
    movf temp,W <-------- copy temp to w (temp = 00h)
    movwf PORTC <-------- copy w to portc (w=00h)
    Where are you setting the individual bits you are talking about?
