Issue with single string character
Results 1 to 5 of 5
    Apr 2011
    Welches, Oregon
    Default Issue with single string character
    So, I have been working on a controller for my aquarium - to turn on lights, control temperature... The project progresses well and a fair number of the features work flawlessly; however a couple of unrelated issues - some PicBasic related and some not - continue to plague me. I'm hoping for some help...
    First, I use a RTC1307 clock module to track time. Each five seconds and each one minute, routines run to update the display and to adjust various parameters. A part of the output is to display the time and date in the format: TH, NOV 27, 14. I store characters in DATA statements and, using the clock registers and READ statements, compose the required strings with the following code:
    '-----SET CALENDAR
    EXPAND_DATE:
    READ 097 + (reg_val[5] * 3) + 0, CA_MONTH[0]
    READ 097 + (reg_val[5] * 3) + 1, CA_MONTH[1]
    READ 097 + (reg_val[5] * 3) + 2, CA_MONTH[2]
    READ 137 + (reg_val[3] * 2) + 0, CA_DAY[0]
    READ 137 + (reg_val[3] * 2) + 1, CA_DAY[1]
    These are the associated DATA statements:
    DATA @ 100, "J", "A", "N", "F", "E", "B", "M", "A", "R", "A", "P", "R", "M", "A", "Y", "J", "U", "N", "J", "L", "Y", "A", "U", "G", "S", "E", "P", "O", "C", "T", "N", "O", "V", "D", "E", "C"
    DATA @ 137, "S", "U", "M", "O", "T", "U", "W", "E", "T", "H", "F", "R", "S", "A", "S", "U"
    And here is the code that puts it together on the 4X20 LCD operating in 4-bit mode:
    '-----UPDATE DISPLAY
    UPDATE_DISPLAY:
    '-----LINE1
    LCDOUT $FE, LINE1, CA_DAY[0], CA_DAY[1], ", ", STR CA_MONTH[0]\1, STR CA_MONTH[1]\1, STR CA_MONTH[2]\1, " ", dec2 REG_VAL[4]
    REG_VAL[3] is the day of the week, REG_VAL[5] is the month and REG_VAL[4] is the 2 digit year. CA_DAY is defined as a byte array [2] and CA_MONTH as a byte array [3]; LINE1 a constant representing position 1 on the first display line.
    Everything works as expected, EXCEPT that the fist day of the month, any month, is always munged - appearing as some unintelligible pattern of dots rather than the first day of the month. It is hard to demonstrate because the pattern of dots is not one defined on the keyboard, but similar to $OV - where "$" would be a scatter-shot of dots. Changing the month, it might be $AN or $EB... Always the first character of the month. The two character day appears as expected (even without the string designator) - added to the month without beneficial effect.
    I've tried PAUSING between reads, reversing the order of the reads... no difference. I've verified the function of the LCD by moving the date to the second line - items on the first line display properly - the date, on the second line, remains munged in the same way as before.
    Anyone see the issue?
    Default Re: Issue with single string character
    since the RTC1307 clock module gives its output data in bcd why not just
    lcdout hex2 reg_val[3]
    also if you need to use it as a binary/dec number for comparisons etc.
    day = ((reg_val[3] >> 4) * 10) + (reg_val[3]$0f) ; bcd2bin conversion
    lcdout dec2 reg_val[3]
    that last line was wrong should be
    lcdout dec2 day
    must have been too early in the morning for me
    Apr 2011
    Welches, Oregon
    lcdout dec2 day
    It took me a moment... I'm blaming it on mashed potato poisoning - self inflicted, don't call the police.
    In fact, I use a similar function to convert the calendar registers to decimal (and back) as part of each read and write routine. The problem comes in trying to use that decimal value to retrieve text characters. The math:
    REG_VAL[5] = 1 in January... So:
    READ 097 + (REG_VAL[5] * 3) + 0 = DATA position 100; CA_MONTH[0] = "J"
    READ 097 + (REG_VAL[5] * 3) + 1 = DATA position 101; CA_MONTH[1] = "A"
    READ 097 + (REG_VAL[5] * 3) + 2 = DATA position 102; CA_MONTH[2] = "N"
    The problem... On the LCD the first character in munged - displays as "$AN", where $ represents some random pattern of dots. When REG_VAL[5] = 2, I get $EB; 3 = $AR... Indicating that the month is correctly decoded and the DATA located properly. As they say, "Everything is perfect, it just don't work".
    The day (MO, TU, WE...) is decoded similarly from REG_VAL[3] (starting at DATA location 137) and displays as it should.
    looks like I got hold of the wrong end of the stick again
    tried this
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 29/11/2014                                        *
    cfg1 = _FOSC_INTOSC
    cfg1&= _WDTE_ON
    cfg1&= _PWRTE_OFF
    cfg1&= _MCLRE_ON
    cfg1&= _CP_OFF
    cfg1&= _CPD_OFF
    cfg1&= _BOREN_ON
    cfg1&= _CLKOUTEN_OFF
    cfg1&= _IESO_ON
    cfg1&= _FCMEN_ON
      __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF
    cfg2&= _PLLEN_OFF
    cfg2&= _STVREN_ON
    cfg2&= _BORV_19
    cfg2&= _LVP_OFF
      __CONFIG _CONFIG2, cfg2
     ;DATA @ 137, "S", "U", "M", "O", "T", "U", "W", "E", "T", "H", "F", "R", "S", "A", "S", "U"
     CA_MONTH var byte[3 ]
     reg_val  var byte
       osccon=$6a    '4 mhz
       anselA=0
      for   reg_val =1 to 12
      gosub expand_date
      Serout2 PORTA.0,84,["m",#reg_val ," ",str ca_month \3 ,13,10]
      next
    EXPAND_DATE:
     READ 097 + (reg_val * 3) + 0, CA_MONTH[0]
     READ 097 + (reg_val * 3) + 1, CA_MONTH[1]
     READ 097 + (reg_val * 3) + 2, CA_MONTH[2]
    result
    m1 JAN
    m2 FEB
    m3 MAR
    m4 APR
    m5 MAY
    m6 JUN
    m7 JLY
    m8 AUG
    m9 SEP
    m10 OCT
    m11 NOV
    m12 DEC
    so the method is sound . reg_val[5] is binary not BCD right ?
    otherwise post entire code , I suspect an array overrun is most likely problem
    ps another method using flash mem not eprom :- for more ideas
    lookup pkt[3],["xmtwtfss"], day[0]
    lookup pkt[3],["xouehrau"], day[1]
    lookup pkt[3],["xnenuitn"], day[2]
  1. Replies: 3
    Last Post: - 3rd December 2011, 22:48
  2. How to send a string with another string inside it?
    Last Post: - 13th May 2011, 17:11
  3. SEROUT command (single byte value not string)
    Last Post: - 12th June 2010, 03:34
  4. sending string to module GSM with character ""
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2010, 02:26
  5. Code Issue - select case or 'if' issue - not sure why
    Last Post: - 7th October 2007, 08:52
