RC servo to PIC controlled via RC transmitter
Results 1 to 15 of 15
    Default Re: RC servo to PIC controlled via RC transmitter
    So you want to send a button press to the pic via a radio signal, and have the PIC control a servo . . . Why not control the servo from the receiver? There MUST BE more to this story . . . BUT Yea that should be do-able use a comparator input to convert signal to a switch input, pic can output servo signals . . . this is right up Acetronics alley, but I would need a bit more information than you have been forthcoming with. Bottom line, whay are you trying to do? Decode a button push, some text?
    Nothing to add ...
    What exactly is to do with that servo ??? "activated" or NOT.
    BTW note the servo ALWAYS is activated ... you just "tell " it the position you want it to reach @ 50 times per second ...
    As Archangel wrote, your R/C set very probably can do that without any added Gadget ...
    Just ... RTFM ( just Read that ... R/C Manual !!! )
    Now, the good question is ...
    Does this pushbutton already exist aboard your transmitter ??? ....
    this could be an interesting story, then.
  1. FM Radio transmitter PIC Interface.
    By koossa in forum Off Topic
    Last Post: - 30th November 2008, 09:05
  2. Single PIC As Both, Wireless Transmitter and Receiver
    By charlieb83 in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2007, 04:35
  3. CD/DVD burner controlled by PIC - Possible?
    Last Post: - 7th August 2007, 08:09
  4. PIC Controlled Current Source
    By Andy Wood in forum mel PIC BASIC Pro
    Last Post: - 30th June 2007, 18:15
  5. PIC controlled serial LCD
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2004, 18:04
