PBP3 stopped generating hex files
Results 1 to 4 of 4
    Default PBP3 stopped generating hex files
    I was using PBP3 and a 3rd party programmer just fine. Then I got labX1. I was playing around with that. Everything was working fine including the U2 programmer. I only used it once.
    Next time I launched microcode studio, everything seemed to work fine. I made some changes to an existing program. The program saved and seemed to compile fine, but when I launched my 3rd party programmer, there was no hex file to be found.
    I plugged the labX1 and U2 programmer back and tried it with that. No those don't work either. The program saves and the compiler status bar says everything is OK, but there is no hex file. Also, if I click on compile and program button, it will not launch the programmer either.
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Default Re: PBP3 stopped generating hex files
    Far from being an expert in this stuff, the same thing happened to me a while ago.
    The solution was the .HEX file saved to a different location (somehow) than normal, so the programmer couldn't find it.
    That MAY be the problem, but no promises.
    Peter Moritz.
    New South Wales,
    Australia.
    Did some research in other forums and found out the problem. You can only have 1 dot in your file name. I had named the file suchandsuchRev1.1.pbp and it wouldn't generate the hex file. Changed it to suchandsuchRev2.pbp and it worked as usual.
    Jun 2005
    Well, always nice for there to be a simple explanation.
    I will file that one away for future reference.
    Peter Moritz.
    New South Wales,
    Australia.
  1. hex files don't agree
    By queenidog in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2013, 01:39
  2. EasyPic5, PicFlash2 and hex files
    By david1800 in forum Off Topic
    Last Post: - 11th July 2011, 08:11
  3. 16F877a, stopped working
    By comwarrior in forum General
    Last Post: - 18th September 2009, 07:39
  4. Compiler not creating .hex files for programmer.
    By Teknikum in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 11:37
  5. Using PBP Hex Files with FED Pic Programmer
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 20th February 2005, 11:57
