Help with the conversion math
Results 1 to 31 of 31
    Mar 2011
    Los Angeles, California
    Default Re: Help with the conversion math
    Hi All and Thanks!
    Just for grins I took a 10K resistor and fed the A/D input pin with 5 volts. The reading I got was 65472! I had to print and scan the data sheet as the one Servoflo has is similar and does not show the .07 psi device I am using. Not sure why when you print 5 pages to a PDF the text scrambles, its Abobe! I will try the suggest code in a few days. Yes it is a 54A-L07-H-2210 a 5 volt device.
    Best, Ed
    And this 65472, isn't the 1023 with left justification?
    At page 157 of the Data sheet, it is shown that the PIC defaults to ADFM at 0 (zero), so it is really Left Justified by default. You have to make it a 1 for Right Justified result.
    The register is the ADCON2 and bit 7.
    Yes, because you have the freaking thing configured wrong for the way that ADCIN works for crying out loud :-)
    Just set the justification bit correct, as Ioannis shows AND as we've already discussed in the other thread where we went thru all this resolution and justification stuff last time.
    OK, so it's a 0.07psi and not 7psi as I based my code around..... Well, then we need to change the scaling but lets see if it works at all first.
    that works out pretty nicely every adc 100 count is almost exactly .01 psi
    0=110 , 0.07 = 820 couldn't be easier
    assuming I read the data sheet properly and that 0.07 psi = 4.0 volts and vref=5 v of course
    Jun 2009
    Sc*nthorpe, UK
    Not quite Richard. In theory
    0=102.4 at 0.5 volts and 0.07=921.6 at 4.5 volts.
    assuming as you say the vref=5 v.
    102.4 is the zero offset and 0.07/(921.6-102.4) is the slope.
    to convert to psi
    psi=(reading-offset)*slope
    psi=(reading-102.4)*0.07/819.2
    psi=(reading-102.4)*0.0000854492.....
    I do seem to remember this is for a depth gauge on a model submarine and am wondering what depth of water is 0.07 psi. The answer is 100 mm of water (99.54mm).
    Giving
    mm of water=(reading-102.4)*0.12207028.....
    just to check at maximum reading = 921.6
    therefore
    mm of water=(921.6-102.4)*0.12207028
    mm of water=99.9999
    I am now wondering if this gauge is suitable?
    Quote Originally Posted by EarlyBird2 View Post
    0.07 psi gauge surely is a differential one ... so, one could reasonnably think it's for measuring SPEED with a pitot tube ...
    just my two cents ...
    Hi, Ed
    Why not download that jewel ???
    http://curveexpert.software.informer...nload/?ca13e51
  1. AD conversion
    By CipiCips in forum mel PIC BASIC
    Last Post: - 19th May 2011, 01:09
  2. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 01:48
  3. PBPL Math...new math takes more cycles...Always?
    Last Post: - 10th February 2008, 10:22
  4. conversion
    By pramodsinha in forum Forum Requests
    Last Post: - 19th January 2006, 15:58
  5. ºC -> ºF Conversion
    By CocaColaKid in forum General
    Last Post: - 15th March 2005, 09:42
