18F25K22 Help
Results 1 to 18 of 18
Thread: 18F25K22 Help
    Jan 2010
    Default Re: 18F25K22 Help
    Actually, I tried multiple settings. I searched throughout this site and even found one instance where Darrel suggested adcon1 = 15, so I tried that. After my post, I changed it to:
      ADCON1 = %00001110             ' set to digital outputs
    The end code I had after the last LED pause was:
     while program = 1
     wend
        relay1 = 0
        relay2 = 0
        relay3 = 0
        relay4 = 0
        led1 = 0
        led2 = 0
        led3 = 0
        led4 = 0
    goto action
    As stated, when the program is initially run, the program waits until the button was pressed. Once pressed, it then runs through the sequence continuously, never stopping at the while loop.
    Now, I did put in the necessary variable at the top of the code so it would acknowledge the button and when it would be pressed, I'm just out of ideas. Anybody have any?
    Tony
    Simplify, blink one LED on/off.
    Edit: I had posted code for this pic but can't find it (on cell phone).
    that snippet shows no possible way to exit the while loop . how CAN THE PROGRAM VAR EVER CHANGE ???
    ADCON1 = %00001110 ' set to digital outputs IS STILL WRONG read the data sheet adcon1 has no effect on setting inputs to digital at all
    post the whole test code
    Jan 2010
    ;----[18F25K22 Hardware Configuration]------------------------------------------
    #IF __PROCESSOR__ = "18F25K22"
      #DEFINE MCU_FOUND 1
      CONFIG  FOSC = INTIO67     ; Internal oscillator block
      CONFIG  PLLCFG = OFF       ; Oscillator used directly
      CONFIG  PRICLKEN = ON     ; Primary clock can be disabled by software
      CONFIG  FCMEN = OFF        ; Fail-Safe Clock Monitor disabled
      CONFIG  IESO = OFF         ; Oscillator Switchover mode disabled
      CONFIG  PWRTEN = OFF       ; Power up timer disabled
      CONFIG  BOREN = SBORDIS    ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
      CONFIG  BORV = 190         ; VBOR set to 1.90 V nominal
      CONFIG  WDTEN = ON         ; WDT is always enabled. SWDTEN bit has no effect
      CONFIG  WDTPS = 32768      ; 1:32768
      CONFIG  CCP2MX = PORTC1    ; CCP2 input/output is multiplexed with RC1
      CONFIG  PBADEN = OFF       ; PORTB<5:0> pins are configured as digital I/O on Reset
      CONFIG  CCP3MX = PORTB5    ; P3A/CCP3 input/output is multiplexed with RB5
      CONFIG  HFOFST = ON        ; HFINTOSC output and ready status are not delayed by the oscillator stable status
      CONFIG  T3CMX = PORTC0     ; T3CKI is on RC0
      CONFIG  P2BMX = PORTB5     ; P2B is on RB5
      CONFIG  MCLRE = INTMCLR    ; RE3 input pin enabled; MCLR disabled
      CONFIG  STVREN = ON        ; Stack full/underflow will cause Reset
      CONFIG  LVP = OFF          ; Single-Supply ICSP disabled
      CONFIG  XINST = OFF        ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
      CONFIG  DEBUG = OFF        ; Disabled
      CONFIG  CP0 = OFF          ; Block 0 (000800-001FFFh) not code-protected
      CONFIG  CP1 = OFF          ; Block 1 (002000-003FFFh) not code-protected
      CONFIG  CP2 = OFF          ; Block 2 (004000-005FFFh) not code-protected
      CONFIG  CP3 = OFF          ; Block 3 (006000-007FFFh) not code-protected
      CONFIG  CPB = OFF          ; Boot block (000000-0007FFh) not code-protected
      CONFIG  CPD = OFF          ; Data EEPROM not code-protected
      CONFIG  WRT0 = OFF         ; Block 0 (000800-001FFFh) not write-protected
      CONFIG  WRT1 = OFF         ; Block 1 (002000-003FFFh) not write-protected
      CONFIG  WRT2 = OFF         ; Block 2 (004000-005FFFh) not write-protected
      CONFIG  WRT3 = OFF         ; Block 3 (006000-007FFFh) not write-protected
      CONFIG  WRTC = OFF         ; Configuration registers (300000-3000FFh) not write-protected
      CONFIG  WRTB = OFF         ; Boot Block (000000-0007FFh) not write-protected
      CONFIG  WRTD = OFF         ; Data EEPROM not write-protected
      CONFIG  EBTR0 = OFF        ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTR1 = OFF        ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTR2 = OFF        ; Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTR3 = OFF        ; Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTRB = OFF        ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    ' -----[ Initialization ]-------------------------------------------------------
    Reset:
      OSCCON = %01010000             ' 4MHz
      TRISA = %00000000              ' sets pin as input (1) or output (0)
      TRISB = %00000001              ' sets pin as input (1) or output (0)
      TRISC = %10001100              ' sets pin as input (1) or output (0)
      PORTA = %00000000              ' sets outputs as high (1) or low (0)
      PORTB = %00000000              ' sets outputs as high (1) or low (0)
      PORTC = %00000000              ' sets outputs as high (1) or low (0)
    ' -----[ Variables ]------------------------------------------------------------
        led1          var   porta.1  ' LED 1
        led2          var   porta.2  ' LED 2
        led3          var   portb.1  ' LED 3
        led4          var   portb.2  ' LED 4
        program       var   porta.0  ' button to restart sequence
    action:
        led1 = 1
        led2 = 1
        led3 = 1
        led4 = 1
     while program = 1          ' loop here until the button is pressed
     wend
        led1 = 0
        led2 = 0
        led3 = 0
        led4 = 0
    goto action
    The current code is written as such: Turn on each LED in sequence and leave them on until the button is pressed. It is a pull down input. When the button is pressed, turn off all the LEDs and repeat the sequence.
    Right now, LED1 turns on and then when LED2 goes to turn on, LED1 turns off. LEDs 2-4 sequence on and stay on, but LED1 stays off. On the first run, the LEDs turn on and stay on until the button is pressed. After the initial press, the LEDs turn on in sequence (except for LED1) and once LED4 is lit, they all turn off and the sequence in repeated.
    Can't figure it out unless it's because of my pins not all being set to digital. I'm asking for help on what the proper code is for setting them all to digital. I keep finding posts where people say read the datasheet. I've read the datasheet and I've entered what I think it is telling me for how to set the pins to all digital. I'm now asking for help.
    GOOGLE "PIC READ MODIFY WRITE"
      #DEFINE MCU_FOUND 1
    #ENDIF
    #IFNDEF MCU_FOUND
    #ENDIF
    Reset:
      ADCON1 = %00001110             ' set to digital outputs            this is totally wrong
    ANSELA=0      WILL SET PORTA DIGITAL
    ANSELB=0      WILL SET PORTB DIGITAL
        led1          var   porta.1  ' LED 1    JUST ASKING FOR READ MODIFY WRITE ISSUES
        led1          var   LATA.1  ' LED 1    CAN ELIMINATE READ MODIFY WRITE ISSUES
        led2          var   LATA.2  ' LED 2
        led3          var   LATB.1  ' LED 3
        led4          var   LATB.2  ' LED 4
    action:
        led1 = 1
        led2 = 1
        led3 = 1
        led4 = 1
     wend
        led1 = 0
        led2 = 0
        led3 = 0
        led4 = 0
    goto action
    May 2012
    Merseyside, UK
    Hi
    Aside from the analog port issues..... If you want the LED's to sequence, you need to put them low at some point otherwise they all going to be mostly high all the time ?
    Maybe as others far wiser than me will suggest (Robert)..... get the code to turn one LED on and off (Flash)
    Move this simple code around the ports.. Then once you know this is working OK... Progress on further.
    flash: ledx high
    ledx low
    goto flash
    BR
    Andy
    What Andy proposed (1 LED) and Richard (RMW).
    Also, put AllDigital back in and doublecheck the code generated.
    Jan 2010
    I would like to thank all those who helped looking over the code. The commands I chose were those that I found on this forum, but did not work. So, with that said, I would like to post what I did that got my program working again.
    First off, ADCON1 = whatever. Don't use it. It'll just screw things up. Second, I did not have any success with Darrel's AllDigital include. Not saying it doesn't work, it just didn't work for me.
    What did get it working again was using ANSELA = 0, ANSELB = 0 and ANSELC = 0. I used ANSEL for setting each register to digital, TRIS for selecting input/output and then PORT for setting the outputs to high or low. This was the first step in setting up my code. Then, you have to change your output variables from port to lat. For instance, my LED variable of LED1 var porta.1 needed to be changed to LED1 var lata.1. You can Google it like it was suggested above, but I found I understood it better when viewing a youtube video of the explanation along with circuit and oscilloscope examples. Just remember, only the outputs get changed from port to lat. Leave the inputs as portx, but change the outputs to latx.
    Thanks again to all those that helped and I hope my explanation will help those in the future.
    Tony
    ANSELx = ANALOG SELECT or inversely Digital Select . . .
    ADCON0 is where you choose which Analog Channel to use
    ADCON1 is where you CHOOSE what your voltage references are & Trigger Select
    ANSELA configures portA Analog or Digital
    ANSELB configures portB Analog or Digital
    ANSELC " " " " " portC Analog or Digital
    ANSELD " " " " " portD Analog or Digital
    ANSELE " " " " " portE Analog or Digital
    All about COMPARATORS Below from Data Sheet
    TABLE 18-2: REGISTERS ASSOCIATED WITH COMPARATOR MODULE
    Name Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register on Page
    ANSELA — — ANSA5 — ANSA3 ANSA2 ANSA1 ANSA0              154
    ANSELB — — ANSB5 ANSB4 ANSB3 ANSB2 ANSB1 ANSB0        155
    CM2CON1 MC1OUT MC2OUT C1RSEL C2RSEL C1HYS C2HYS C1SYNC C2SYNC 318
    CM1CON0 C1ON C1OUT C1OE C1POL C1SP C1R C1CH<1:0>    317
    CM2CON0 C2ON C2OUT C2OE C2POL C2SP C2R C2CH<1:0>    317
    VREFCON1 DACEN DACLPS DACOE — DACPSS<1:0> — DACNSS 347
    VREFCON2 — — — DACR<4:0>                                             348
    VREFCON0 FVREN FVRST FVRS<1:0> — — — —                      344
    INTCON GIE/GIEH PEIE/GIEL TMR0IE INT0IE RBIE TMR0IF INT0IF RBIF 116
    IPR2 OSCFIP C1IP C2IP EEIP BCL1IP HLVDIP TMR3IP CCP2IP   129
    PIE2 OSCFIE C1IE C2IE EEIE BCL1IE HLVDIE TMR3IE CCP2IE    125
    PIR2 OSCFIF C1IF C2IF EEIF BCL1IF HLVDIF TMR3IF CCP2IF     120
    PMD2 — — — — CTMUMD CMP2MD CMP1MD ADCMD                 57
    TRISA TRISA7 TRISA6 TRISA5 TRISA4 TRISA3 TRISA2 TRISA1 TRISA0 156
    TRISB TRISB7 TRISB6 TRISB5 TRISB4 TRISB3 TRISB2 TRISB1 TRISB0 156
    Comparators are really good at causing you to tear out your hair while trying to get the PIC to do digital too.
    Sorry this post comes too late to help you, I bet you won't forget though. Keep up the good work Tony.
    JS
    just for the record what version of alldigital.pbp did you try ? there are a number of versions
    is not right ,it just does not do what you erroneously thought it did as archangel says
    and needs to set appropriately " rtfm "
  1. migration from 16F876a to 18F25k22
    By MOUNTAIN747 in forum General
    Last Post: - 19th March 2012, 21:33
  2. Config 18F25K22
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 26th April 2011, 19:08
