Darrel Taylor - Archived pages of DT Interrupts
+ Reply to Thread
Results 1 to 22 of 22
    Sep 2009
    Default Re: Darrel Taylor
    Here it is
    http://dt.cambs.net/
    EDIT:
    Sorry didn't check link before posting.
    Too bad. His Customer Character Generator link doesn't work.
    pedja089 you are a gentleman and a scholar.
    George
    If you have mister_e 's PIC Multicalc, it has those functions. http://www.picbasic.co.uk/forum/atta...4&d=1162909841
    Oops!, here is a newer version: http://www.picbasic.co.uk/forum/atta...7&d=1225550328
    Last edited by Archangel; - 21st November 2014 at 19:18. Reason: add link to picmulticalc
    Here is another question:
    Anyone have a working link to find DT_Analog.PBP ?
    Been searching, but no luck - - lots of links that no longer work
    Ken
    Sep 2009
    I don't have link, but I have saved include file
    'http://www.darreltaylor.com/DT_Analog/
    '*  Name    : DT_Analog.pbp                                     *
    '*  Author  : Darrel Taylor                                     *
    '*  Notice  : Copyright (c) 2009                                *
    '*  Date    : 5/23/2009                                         *
    '*  Notes   : Up to 16 bit A/D with a 10-bit A/D converter      *
    '*          : http://en.wikipedia.org/wiki/Oversampling         *
    GOTO OverDTAnalog
    ADchan       VAR BYTE        ; global - A/D channel to use
    ADbits       VAR BYTE        ; global - # of bits in result
    ADvalue      VAR WORD        ; global - the final A/D value
    ADmax        VAR WORD        ; global - Max A/D value at this resolution
    DTadCount    VAR WORD        ; local - sample count
    DTadDivisor  VAR WORD        ; local - averaging divisor
    DTadShiftR   VAR BYTE        ; local - bits to shift for UnderSampling
    #IF  __LONG__
        DTadAccum    VAR LONG ; local - 32-bit sample accumulator
    #ELSE
        DTadAccum    VAR WORD[2]     ; local - 32-bit sample accumulator
    #ENDIF
    GetADC:
      IF (ADbits >= 10) THEN
        DTadShiftR = 0   ; 10 11 12 13  14   15   16
        LOOKUP2 ADbits-10,[ 1, 4,16,64,256,1024,4096],DTadCount
        LOOKUP  ADbits-10,[ 1, 2, 4, 8, 16,  32,  64],DTadDivisor
        DTadCount = 1
        DTadDivisor = 1
        DTadShiftR = 10 - ADbits
      LOOKUP2 ADbits,[0,1,3,7,15,31,63,127,255,511,1023, _
                      2046,4092,8184,16368,32736,65472],ADmax
      DTadAccum = 0 : DTadAccum[1] = 0     ; clear the accumulator
    DTadLoop:
      ADCIN  ADchan, ADvalue               ; get 10-bit sample
      DTadAccum = DTadAccum + ADvalue      ; add it to the accumulator
      #IF not __LONG__
          IF DTadAccum < ADvalue THEN           ; if low word overflowed
             DTadAccum[1] = DTadAccum[1] + 1   ;   increment the high word
      #ENDIF
      DTadCount = DTadCount - 1            ; done with this sample
      IF DTadCount > 0 THEN DTadLoop       ; loop if not done with ALL samples
      #IF __LONG__
          ADvalue = DTadAccum / DTadDivisor
      #ELSE
          R2 = DTadAccum                       ; put 32-bit accumulated value in PBP
          R0 = DTadAccum[1]                    ;   registers, prepare for DIV32
          ADvalue = DIV32 DTadDivisor          ; get the average value
      #ENDIF
       ADvalue = ADvalue >> DTadShiftR      ; Shift right if < 10-bit
    OverDTAnalog:
    EDIT:
    Here is saved page
    http://web.archive.org/web/201201210...com/DT_Analog/
    Aug 2003
    This sux bigtime
    How did anyone find out? Did someone know him personally?
    I somehow pictured him in my mind in his 40’s or so.
    I wondered where he had gone, but assumed he just moved on as some others have.
    There is a thread here I will never forget, and I wish he’d seen the outcome.
  1. Darrel Taylor Interrupts and MultiCalc
    By AvionicsMaster1 in forum General
    Last Post: - 14th February 2012, 06:18
  2. Darrel Taylor - Instant Interrupts-Problem 16F877A
    Last Post: - 31st December 2009, 13:19
  3. Timer1 and Timer2 interrupts, Darrel Taylor
    By ronbowalker in forum mel PIC BASIC Pro
    Last Post: - 17th December 2009, 18:38
  4. To Mr. Darrel Taylor once again
    By atwoz in forum mel PIC BASIC Pro
    Last Post: - 10th December 2009, 19:10
  5. Darrel Taylor Interrupts I2C Problem
    By dcorraliza in forum mel PIC BASIC Pro
    Last Post: - 26th March 2008, 02:13
