Pulse Out
Results 1 to 6 of 6
Thread: Pulse Out
    Dec 2004
    USA
    Question Pulse Out
    What is the difference between:
    1.
    HIGH portx.n
    pause 10
    LOW portx.n
    2.
    portx.n = 1
    pause 10
    portx.n = 0
    3.
    PULSEOUT portx.n, 1000
    Klaus
    The main difference will be the amount of code generated.
    Due to my fear(or challenge depending) of bad code space usage, i'll use your example #2. Yeah in that case you must set the according TRIS register but... it's always a good practice to do it anyway
    Dec 2004
    USA
    Thanks for the quick reply Steve.
    When I tried it, I found that #3 used the least amount of code, but I'll go back and count those bytes again just to make sure.
    Klaus
    Can be right or wrong depending on how m,any time you use the Pulseout in the same code, do a simple copy/paste 2-3-4-5 times and compare all of your 3 method. I bet the second will take less codespace or really close to. Well just a bet. My brain-cells and fingers feel lazy now...
    Dec 2004
    USA
    Finally had time to run some quick experiments.
    Option #1 added 14 bytes
    Option #2 added 10 bytes
    and Option #3 added a healthy 100 bytes to my code.
    Looks like you were right Steve, but I ran these at 1AM. Results at that time (for me at least) are probably as reliable as results after 3 or 4 beers.
    BR
    Klaus
    Quote Originally Posted by khoog
    good apertizer
  1. Pulse Capture and byte building
    Last Post: - 21st July 2009, 02:59
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. Replies: 3
    Last Post: - 13th September 2008, 18:40
  4. Not quite got my finger on the pulse
    By Sean_Goddard in forum mel PIC BASIC Pro
    Last Post: - 27th January 2007, 13:32
  5. Pulse Frequency Multiplication
    By jamie_s in forum mel PIC BASIC Pro
    Last Post: - 21st August 2005, 11:39
