PCF8574 Example…..
Results 1 to 4 of 4
    Default Re: PCF8574 Example…..
    Is there a way of outputting 1's (Source) when true without using external transistor ?
    according to my data sheet the Io source current is 300uA where the Io sink current is 25mA , is 300uA enough ? if not no
    Why yes you do, The device reads the condition of the output pins, Therefore if you were to set all of the pins low, so as to be sinking current, the readback data would be 00000000. If you want to readback say 4 of the pins that are connected as inputs, you would always mask the output byte with the appropriate input pins set to true. say you want the upper 4 bits to be used as inputs and the lower 4 to be used as outputs, you would always send the output byte masked with 1111 in the upper bit positions by ORING it with %11110000 just before sending it to the device. Then when reading the the device you would mask off the output bits by ANDING the returned byte with %11110000. I have used these I/O expanders for years and they word very well.
    EN82fn
    May 2012
    Merseyside, UK
    Hi David
    I am a hardware engineer so talk simple to me... :-)
    Maybe an example would help me... If can get it to do what I want will move over to the 16Bit version 8 in 8 out.
    Also a radio ham G7IIF
    Thank you for help
    73 de Andy
  1. Pic12f675 + Pcf8574 + Lcd
    By Bostjan in forum mel PIC BASIC Pro
    Last Post: - 4th November 2016, 17:54
  2. troubles using more than one PCF8574
    By maus in forum mel PIC BASIC Pro
    Last Post: - 28th July 2007, 19:37
  3. pcf8574
    By gabi mihai in forum PBP Wish List
    Last Post: - 15th March 2007, 20:10
  4. PCF8574 library - Proteus
    By pgsabel in forum mel PIC BASIC Pro
    Last Post: - 16th May 2005, 09:09
  5. Pcf8574
    By larryt in forum mel PIC BASIC Pro
    Last Post: - 4th December 2004, 21:24
