Hi guys, I didn't use serial communication before ad now I'm trying to learn basics with a simple circuit. I wandered on forums and read most of topics but can't find where my mistake is.
I'm trying to establish a serial communication between 2 16f877a. First one has switches on portb, reading then sending them via serial with hserout. Second one has leds on portb, receiving data from serial and then writing on portb.
Altough its a very simple circuit, I cannot make it work. I simulate circuit on protheus, it looks like data is transmitting from first one but can't proccess it on second I think. Can't find the problem, can you help me please? here are my codes.
Note; I commented out some lines from original code to make things simplier for trying.
Transmitter Code
Receiver CodeCode:TRISB=111111 TRISC=000000 TRISD=000001 define OSC 16 DEFINE HSER_RCSTA 90h '(alma yazmacının Enable edilmesi) DEFINE HSER_TXSTA 20h '(gönderme yazmacının Enable edilmesi) DEFINE HSER_BAUD 9600 '(Haberlesme hızının belirlenmesi) PORTB=0 PORTC=0 PORTD=0 veri var byte lastveri var byte symbol bt0=PORTD.0 clear basla: 'if bt0=0 then veri=PORTB 'endif 'if veri!=lastveri then ' lastveri=veri hserout [veri] while not TXSTA.1 : WEND 'endif goto basla end
Code:TRISB=000000 TRISC=000000 define OSC 16 DEFINE HSER_RCSTA 90h '(alma yazmacının Enable edilmesi) DEFINE HSER_TXSTA 20h '(gönderme yazmacının Enable edilmesi) DEFINE HSER_BAUD 9600 '(Haberlesme hızının belirlenmesi) PORTB=0 PORTC=0 veri1 var byte lastveri1 var byte clear basla1: hserin [veri1] while not PIR1.5 : wend 'if veri!=lastveri then ' lastveri=veri PORTB=veri1 'endif goto basla1 end
					 Trying to learn HSERX usage
