Differential signals applied at speed
Results 1 to 5 of 5
    Feb 2012
    PERTH AUSTRALIA
    Default Differential signals applied at speed
    HI guys this is one i have not tried as yet , and wonder if its at all possible
    i have high speed differential optic TIA (600mhz) connected to a 2nd stage amp with high gain , with outputs that are also differential at 3.3v
    the output gives 15ns - 100ns pulses , which i need to count / check further in the pic for pattern / timing
    is there a way that i can interface directly to the PIC todo the pattern checking and counting on a 18f 64mhz device ?
    if not any other interface suggestions such that the pic could do it
    Cheers
    sheldon
    Default Re: Differential signals applied at speed
    its hardly likely
    min interrupt pulse width is 20nS
    min recognition time for int on pin change is 62.5 nS (Tcyc)
    you would need several uS between pulses to calculate the simplest things
    Feb 2012
    PERTH AUSTRALIA
    yep i thought as much , what i need to slow the signals down , so the pulse train is the same but at 100 times slower , not sure how i can do that
    Aug 2008
    Portugal
    Probably FPGA is the way to go!
    Thanks and Regards;
    Gadelhas
    Feb 2012
    PERTH AUSTRALIA
    yes i been looking at delving into those , i have a hope that the repeated pattern may be matched by a synchronizing sampler cct pulses i am expecting and as a result slow them down
  1. Replies: 26
    Last Post: - 13th November 2010, 07:57
  2. Replies: 0
    Last Post: - 7th August 2008, 10:02
  3. IR signals
    By ruijc in forum General
    Last Post: - 14th May 2008, 15:53
  4. 3.3v signals to 5v signals
    By InitialDriveGTR in forum Schematics
    Last Post: - 7th February 2007, 23:43
  5. Differential Drive Programming
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 30th December 2006, 15:03
