HSEROUT Problem
Results 1 to 3 of 3
Thread: HSEROUT Problem
    Keith's Avatar
    Keith Guest
    Default HSEROUT Problem
    I hve a strange problem using a Pic 16F88 and HSEROUT. The problem seems to be that when I sent a string of data thru HSEROUT (example: "AAAAA") that the very first sent it works great but from then on it seem to change the string ( on the receiving side a PC) to "PPPPP". I have tried all baud rates from 2400 to 38400 and it happen the same on all of them. I've striped by code down to just the HSEROUT and some pauses/sleep then back to the loop to sent again. I thought it might be the sleep, but I removed it and it didn't fix the problem. Any though???? Should I use serout maybe?? Any help would be great.
    Thanks...
    Talking
    If you still run V2.45 i hope you did the update
    http://www.melabs.com/support/patches.htm
    If not, Post your whole code and crystal speed. I did a buch of stuff with F88 and HSEROUT without problem.
    There's absolutely no need to use SEROUT or else. Too much code ungry and poor internal PIC ressource use wich is a REALLY bad practice.
    Keith's Avatar
    Keith Guest
    Default Hserout problem
    Thanks for the reply... I added some timing, Pause 10, before and after transmission and it has helped, but still see the problem once in a while, which means I still have the problem. One thing I didn't mention is that I am using an RF link (going from the Pic to a Linx usb chip connected to my PC). It has worked consistenly on a Laptop, but I connected to a desktop PC and it started having problems. I had to develop my own transmit protocal since I can't use or don't want to implement a transceiver solution. Since I went to the desktop I suspect it's a timing issue on the receiving end thru the usb chip to the PC. Has anyone implemented a solution like this???
    Thanks again....
  1. I2C Slave with a PIC
    By ralfmayr in forum mel PIC BASIC Pro
    Last Post: - 21st August 2016, 18:44
  2. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 20:12
  3. Is HSEROUT corrupting bit 7 ?????
    By Robert Wells in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2008, 17:26
  4. HSEROUT problem at 20MHz
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 27th May 2006, 23:55
  5. Advantages of HSerout over Serout2 and a problem
    By rpstroj in forum mel PIC BASIC Pro
    Last Post: - 11th August 2004, 23:19
